  • 27
quietriot1983
Message 1 of 21
Buffering and stuttering of streaming content
Never had an issue before, but last couple of days things like netflix and other streaming services have been buffering and stuttering like crazy. Really annoying considering I pay for a 100mbit connection (which I do get most of the time).
A recent speedtest produced 68mbps, which should be absolutely ample to stream content, but the issue is obviously dropped hops and excessive latency (see trace below)
Wondering if this is related to the superhub intel chip issue I keep reading about??
Tracing route to www.bbc.net.uk [212.58.244.67]
over a maximum of 30 hops:
1 11 ms 7 ms 4 ms 192.168.0.1
2 23 ms 16 ms 11 ms 10.19.148.1
3 38 ms 35 ms 39 ms leed-core-2a-xe-814-0.network.virginmedia.net [8
0.0.50.189] 7 minutes ago
teecee Avatarteecee: 1 11 ms 7 ms 4 ms 192.168.0.1
2 23 ms 16 ms 11 ms 10.19.148.1 7 minutes ago
teecee Avatarteecee: 3 38 ms 35 ms 39 ms leed-core-2a-xe-814-0.network.virginmedia.net [8
0.0.50.189]
4 * * * Request timed out.
5 31 ms 32 ms 29 ms telw-ic-2-ae5-0.network.virginmedia.net [62.253.
174.81] 6 minutes ago
teecee Avatarteecee: 6 26 ms 31 ms 26 ms 212.58.229.113
7 * * * Request timed out.
8 * * * Request timed out.
9 24 ms 25 ms 33 ms ae0.er02.telhc.bbc.co.uk [132.185.254.105]
10 30 ms 39 ms 31 ms
  • 16.5K
  • 1.38K
  • 3.37K
Message 2 of 21
Re: Buffering and stuttering of streaming content
hiya @quietriot1983 do you have a hub3?, the traceroute is showing not too bad Would need to check the signal levels if could go to http://192.168.0.1 clicking router status top right [no need to login] and if could copy/paste the downstream, upstream, network log, don't worry about the formatting we can easily read it..
  • 27
quietriot1983
Message 3 of 21
Thanks for the quick reply - here goes.
Channel	Frequency(Hz)	Power
(dBmV)	SNR
(dB)	Modulation	Channel ID
1	298750000	-1.5	38.6	256 qam	17
2	322750000	-1.2	38.9	256 qam	20
3	314750000	-1.4	38.6	256 qam	19
4	306750000	-1.5	38.9	256 qam	18
5	290750000	-1.7	38.6	256 qam	16
6	282750000	-1.5	38.6	256 qam	15
7	274750000	-1.7	38.9	256 qam	14
8	266750000	-1.5	38.9	256 qam	13
9	258750000	-1.2	38.6	256 qam	12
10	250750000	-1.2	38.6	256 qam	11
11	242750000	-1	38.9	256 qam	10
12	234750000	-0.7	38.9	256 qam	9
13	226750000	-0.5	38.6	256 qam	8
14	218750000	-0.2	38.9	256 qam	7
15	210750000	0.2	38.6	256 qam	6
16	202750000	0.4	38.9	256 qam	5
17	194750000	0.5	40.3	256 qam	4
18	186750000	0.7	40.3	256 qam	3
19	178750000	0.7	40.3	256 qam	2
20	170750000	1	40.9	256 qam	1
Channel ID	Frequency(Hz)	Mode	Power
(dBmV)	Modulation	Channel Bandwidth(Hz)	Symbol Rate (ksps)
92	25800000	ATDMA	41.8	16 qam	6400000	5120
90	39400000	ATDMA	41.8	16 qam	6400000	5120
Refresh data
Date And Time	Error Number	Event Description
2017-08-31 10:10:27.00	68010100	DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-01 06:42:25.00	82000200	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-01 06:42:28.00	68010100	DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-01 06:44:55.00	68010400	DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-01 09:01:53.00	82000200	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-05 17:59:26.00	68010100	DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-06 09:45:24.00	82000200	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-06 13:03:04.00	84000500	SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-06 13:03:04.00	84000700	RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-06 13:03:09.00	84020200	Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-06 13:03:19.00	82000400	Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-06 13:03:28.00	82000200	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-06 15:55:36.00	68010100	DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-06 20:41:10.00	82000200	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-06 21:24:39.00	68010100	DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-06 23:14:23.00	68010400	DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-10 06:39:06.00	68010100	DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-11 04:18:37.00	68010400	DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-12 23:47:45.00	82000200	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 16.5K
  • 1.38K
  • 3.37K
Message 4 of 21
Stats are showing not too bad, would be around a week for the forum admin to run checks for network utilisation, when your testing is this via wired/wireless?, if it's wireless can you test it via wired
  • 27
quietriot1983
Message 5 of 21
The tests run yesterday were wired to PC, and the issue is occuring when streaming (wired) to Amazon fire TV, and also when gaming (wired, via Gigabit switch) on PS4.
  • 27
quietriot1983
Message 6 of 21
More rubbish
Pinging www.bbc.net.uk [212.58.244.26] with 32 bytes of data:
Reply from 212.58.244.26: bytes=32 time=101ms TTL=52
Reply from 212.58.244.26: bytes=32 time=78ms TTL=52
Reply from 212.58.244.26: bytes=32 time=23ms TTL=52
Reply from 212.58.244.26: bytes=32 time=29ms TTL=52
Tracing route to www.bbc.net.uk [212.58.244.26]
1 4 ms 6 ms 2 ms 192.168.0.1
2 * * * Request timed out.
3 21 ms 12 ms 16 ms manc-core-2a-xe-012-0.network.virginmedia.net [82.15.206.65]
5 27 ms 22 ms 19 ms telw-ic-2-ae5-0.network.virginmedia.net [62.253.174.81]
6 43 ms 30 ms 25 ms 212.58.229.113
9 20 ms 22 ms 19 ms ae0.er02.telhc.bbc.co.uk [132.185.254.105]
10 29 ms 26 ms 29 ms 132.185.255.148
11 19 ms 28 ms 28 ms bbc-vip145.telhc.bbc.co.uk [212.58.244.26]
  • 16.5K
  • 1.38K
  • 3.37K
Message 7 of 21
Tracerouting showing fine, and the ping test might have a small spike since sure all icmp traffic aka ping will have a very low cpu priority
  • 27
quietriot1983
Message 8 of 21
How can you say tracerouting is fine when the FIRST hop outside of my house times out?!
  • 1.46K
  • 87
  • 344
cje85
Knows their stuff
Message 9 of 21
Time outs on traceroutes are normal on VM's network as the servers treat ping requests as low priority (if they reply at all).
  • 27
quietriot1983
Message 10 of 21
Ah right, is video streaming and online gaming low priority as well then?
You're saying it's definitely nothing to do with the Puma chip that has a 150+ page thread?
