  • 10
Oscargps9
Message 1 of 8
Broadband
Hello .....yes broadband....its only ever broadband. Very very slow again and router drops out and keeps rebooting at least 20 times a night. When it comes back speed is around 2 .....utter rubbish. Seems to behappening more and more. Anyone else got issues? Im in area 3.
I ask for a test to be done online and comes back as ok.....well it will wont it as I cant get on line to ask them to do it when its down!!!!!
  • 8.63K
  • 552
  • 2.38K
Message 2 of 8
Re: Broadband
So we can help us to help you, can you
Go to your Superhub Log in screen
Do NOT log in.
Little button top right.....
Can you post Upstream, Downstream and Network logs.
Screen caps are nice, C&P will do- Don't stress about formatting if you C&P. Someone will get a look and see if there's anything obvious amiss.
  • 10
Oscargps9
Message 3 of 8
Re: Broadband
After it dropped out for the 9th time this evening I phoned Virgin. It came back when I was on the phone and I ran another speedtest. Download very poor. The lady said there are too many things connected to the broadband. There are only 2 wired to router and laptops, phones, sonos etc only connect when on(There is obviously a limit of 4) . So I reset router and disconnect everything except the laptop Im typing this on. Speedtest shown. Dropped out again typing this message. I can not log into the routet using ip ....keeps showing as connection timed out
Fastest its been tonightFastest its been tonight
  • 10
Oscargps9
Message 4 of 8
Re: Broadband
So finally managed to log on....network log not helpful as router was reset. By the way current speed according to speedtest is 1.1.....!!
  • 8.63K
  • 552
  • 2.38K
Message 5 of 8
Re: Broadband
Power levels are high but within spec. SNR is low, but again within spec.
Wait for staff to get a look, and run some diagnostics their end.
  • 14.45K
  • 641
  • 1.46K
Moderator
Moderator
Message 6 of 8
Re: Broadband
Hi Oscargps9,
Sorry to hear you're getting poor speeds and drop outs. I've checked your connection from here as well as the stats you've posted and can see that there is a contention fault in the area under ticket F004659000. This will explain the poor speeds and is due for review 22/03/17. Other than that the power levels don't look too healthy and will need a technician to visit. I've just sent you a private message to arrange the best time for this. You can see your private messages by clicking the envelope at the top of the page.
  • 10
Oscargps9
Message 7 of 8
Re: Broadband
So an engineer attended ...said my hub was from the dark ages and not working properly....he fitted a new superhub 3. Had to wait a while for the walled garden but its up and running now. Cheers guys.....this is a bit of a difference.
  • 7.59K
  • 188
  • 442
Message 8 of 8
Re: Broadband
Hi Oscargps9,
Thanks for getting back in touch, I am glad to see things are looking better for you now.
If you do need us to take a look at the connection in the future we will be more than happy to do so.
All the best
Emma
