  • 11
julie51
Message 1 of 16
Broadband
I have opted for 200 mbs broadband but am only getting 150 max is this normal?
  • 16.45K
  • 1.37K
  • 3.36K
Message 2 of 16
Re: Broadband
hiya @julie51 is this via wired/wireless?, if its via wireless can you test via wired, also to check what package your on, if you can goto http://192.168.0.1 clicking router status top right no need to login, and if can copy/paste the operational config.
  • 11
julie51
Message 3 of 16
Re: Broadband
Hello
Speed test was wireless
I have tried wired but only get about 100 mbs.I am really surprised .Could it be because the router is hard wired
to new tivo box 6?
I have copied you router status
Thanks for your help
julie
Hub 3.0 status overview
Your Hub 3.0 status
 Wireless(On (2.4 and 5GHz), WPS Enabled)
 Internet(Online)
Telephony(Disabled)
Telephony(Disabled)
Wireless connected devices: 2
DESKTOP-O9KMMG8
Nizar
Ethernet Connected devices: 1
TIVO-C680000200C4391
  • 22.22K
  • 844
  • 3.23K
Message 4 of 16
Re: Broadband
if you only get 100 wired then it might be down to your hardware. what colour is the light on the network port on the superhub?
Also can you run ipconfig /all from a command prompt and paste the output here
  • 11
julie51
Message 5 of 16
Re: Broadband
Base led light is white/blue
I am afraid i do not know hot to run ipconfig.
SORRY
  • 16.45K
  • 1.37K
  • 3.36K
Message 6 of 16
Re: Broadband
if you do the following press the windows key + r and type in ipconfig > c:\results.txt this will create a file called results.txt into the root of your c:\ if you open this file and copy and paste the contents here
  • 11
julie51
Message 7 of 16
Re: Broadband
I tried what you suggested but I could not find the file saved in my C:\.
It just flashed the report in the background and it disappeared.
Not sure what I am doing wrong as I followed your instructions.
Please let me know what I am doing wrong.
Thank you
  • 16.45K
  • 1.37K
  • 3.36K
Message 8 of 16
Re: Broadband
http://community.virginmedia.com/t5/General-broadband-questions/VMDG280-Virgin-Netgear-router-is-unw... yeah small black box should appear and disappear, depends on what settings are on machine other way would be doing the following press windows key + r type in cmd press enter on the keyboard, a small black box will appear type in
ipconfig /all > results.txt (nothing wil appear on screen apart from what you typed) on the next line type in results.txt and notepad will open with the contents if you can copy and paste the contents of that file here and you can then close notepad and x the blackbox
if that doesn't work can you post what version of windows your using e.g. xp, vista, 7,8,10
  • 11
julie51
Message 9 of 16
Re: Broadband
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-O9KMMG8
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller #2
Physical Address. . . . . . . . . : **:**:**:**:**:**
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Kaspersky Security Data Escort Adapter
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 3165
Link-local IPv6 Address . . . . . : fe80::a5e2:90d:b27a:e41e%17(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.11(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 20 January 2017 10:11:10
Lease Expires . . . . . . . . . . : 21 January 2017 12:07:21
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 122434696
DHCPv6 Client DUID. . . . . . . . : **:**:**:**:**:**-**:**:**:**:**:**-CD-CF
DNS Servers . . . . . . . . . . . : 194.168.4.100
194.168.8.100
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Reusable ISATAP Interface {1A398186-B6E4-4698-9442-5AFA6C3B9C47}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : **:**:**:**:**:**-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 3:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
 is this what you need! Hope it helps
Thanks -you are very helpfull
FYI -am using windows 10
  • 11
julie51
Message 10 of 16
Re: Broadband
HI
Did you get my message / manage to find what the problem is!
Would appreciate your input
julie
