  • 5
NickBow
Message 1 of 7
Broadband speed
Over last few days have had trouble viewing BBC TV and i Player and also TV anywhere on my Mac desktop. Ran a speed test several times and i am only getting download speeds of between 3 and 9 Mbps and upload speeds of 7 and 11. I am supposed to have 150 through a super hub and i have an ethernet cable from the hub directly into the Mac. Why am i paying for 150 when i don't seem to get anywhere near that? or do i only get that speed on a Sunday at 4.00am?
Helpful Answers
  • 16.52K
  • 1.38K
  • 3.38K
Message 6 of 7
Re: Broadband speed
Your downstream levels are showing a bit on the low side as well as the signal to noise ratios, this more than likely will require a tech visit you can wait a forum admin to arrange or call broadband support via 151 / 0345 454 1111
All Replies
  • 16.52K
  • 1.38K
  • 3.38K
Message 2 of 7
Re: Broadband speed
hiya @NickBow Would need to check the signal levels if could go to http://192.168.0.1 clicking router status top right [no need to login] and if could copy/paste the downstream, upstream, network log, don't worry about the formatting we can easily read it..
  • 5
NickBow
Message 3 of 7
Re: Broadband speed
Hi Paultechy,
See results below, hope that helps. Thanks.
Activity Summary
See how much data you have uploaded and downloaded since your Super Hub was last power cycled (that's switched on or rebooted). This information will be automatically reset when you next power cycle your Super Hub, or you can reset it manually.
Session Time   1day 12h:06m:58s
Session Data Downloaded   6,794 MB
Session Data Uploaded   441 MB
Devices Connected
See which wired and wireless devices are connected to your Super Hub and how long they've been connected.
Wired Devices MAC Address IP Address Device Name Time Connected
**:**:**:**:**:** 192.168.0.2 Macintosh 0days 00hrs 53mins 46s
Wireless Devices MAC Address IP Address Device Name Time Connected
**:**:**:**:**:** 192.168.0.7 amazon-d81bc8c13 0days 12hrs 23mins 45s
**:**:**:**:**:** 192.168.0.8 Denises-iPhone 0days 00hrs 23mins 21s
**:**:**:**:**:** 192.168.0.5 Macintosh 0days 00hrs 15mins 38s
**:**:**:**:**:** 192.168.0.6 Apple-TV 0days 00hrs 53mins 46s
**:**:**:**:**:** 192.168.0.10 Nicks-Lenovo 0days 00hrs 03mins 10s
WAN IP Address
WAN IP Address  81.107.*******
[MOD EDIT: For your security personal and private information has been removed from this post. Please review the Forum Guidelines]
  • 16.52K
  • 1.38K
  • 3.38K
Message 4 of 7
Re: Broadband speed
Didn't really need that, when going to hub page should be text for router status that will give info about downstream, upstream etc
  • 5
NickBow
Message 5 of 7
Re: Broadband speed
Sorry could not find where you meant initially, hope below helps and apologies for the formatting Downstream DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8 Frequency (Hz) 299000000 267000000 275000000 283000000 291000000 307000000 315000000 323000000 Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked Channel ID 33 29 30 31 32 34 35 36 Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 Interleave Depth I=12 J=17 I=12 J=17 I=12 J=17 I=12 J=17 I=12 J=17 I=12 J=17 I=12 J=17 I=12 J=17 Power Level (dBmV) -4.40 -6.71 -5.84 -6.43 -3.45 -2.61 -2.95 -3.58 RxMER (dB) 33.83 33.60 34.35 34.21 34.21 34.35 34.48 34.63 Pre RS Errors 413878 1979177 2935391 4090640 500718 270368 408452 353881 Post RS Errors 12392 45462 47431 19082 9803 10707 13100 117 Upstream US-1 US-2 US-3 US-4 Channel Type 2.0 N/A N/A 2.0 Channel ID 26 N/A N/A 25 Frequency (Hz) 39400000 N/A N/A 46200000 Ranging Status Success N/A N/A Success Modulation 16QAM N/A N/A 16QAM Symbol Rate (Sym/sec) 5120000 N/A N/A 5120000 Mini-Slot Size 4 N/A N/A 4 Power Level (dBmV) 53.25 N/A N/A 55.21 T1 Timeouts 5 5 5 5 T2 Timeouts 0 0 0 0 T3 Timeouts 0 0 0 0 T4 Timeouts 0 0 0 0 Network Log First Time Last Time Priority Error Number Description 14/09/2017 21:54:02 GMT 14/09/2017 21:54:02 GMT Warning (5) 66050310 Auth Success - Web login successful. 14/09/2017 21:53:50 GMT 14/09/2017 21:53:50 GMT Warning (5) 66050310 Auth Success - Web login successful. 14/09/2017 21:53:36 GMT 14/09/2017 21:53:36 GMT Warning (5) 66050300 Auth Fail - Web login failed. 14/09/2017 21:53:16 GMT 14/09/2017 21:53:16 GMT Warning (5) 66050300 Auth Fail - Web login failed. 14/09/2017 08:23:28 GMT 14/09/2017 08:23:28 GMT Warning (5) 66050310 Auth Success - Web login successful. 14/09/2017 08:22:49 GMT 14/09/2017 08:22:49 GMT Warning (5) 66050300 Auth Fail - Web login failed. 12/09/2017 21:00:05 GMT 12/09/2017 21:00:05 GMT Error (4) 68010302 DHCP WAN IP - ########## 12/09/2017 20:59:25 GMT 12/09/2017 20:59:25 GMT Error (4) 68000407 TOD established 12/09/2017 20:59:11 GMT 12/09/2017 20:59:11 GMT Notice (6) 84000510 Downstream Locked Successfully 12/09/2017 20:58:33 GMT 12/09/2017 20:58:33 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out 12/09/2017 20:57:33 GMT 12/09/2017 20:57:33 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out 12/09/2017 20:56:33 GMT 12/09/2017 20:56:33 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out 12/09/2017 20:55:33 GMT 12/09/2017 20:55:33 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out 12/09/2017 20:54:33 GMT 12/09/2017 20:54:33 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out 12/09/2017 20:53:33 GMT 12/09/2017 20:53:33 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out 12/09/2017 20:52:33 GMT 12/09/2017 20:52:33 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out 12/09/2017 20:51:50 GMT 12/09/2017 20:51:50 GMT Error (4) 67070100 DBC-ACK not received 12/09/2017 20:51:48 GMT 12/09/2017 20:51:48 GMT Warning (5) 85010200 TCS Partial Service 12/09/2017 20:51:42 GMT 12/09/2017 20:51:42 GMT Error (4) 68010302 DHCP WAN IP - ########## 12/09/2017 20:51:03 GMT 12/09/2017 20:51:03 GMT Error (4) 68000407 TOD established
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 16.52K
  • 1.38K
  • 3.38K
Message 6 of 7
Re: Broadband speed
  • 5
NickBow
Message 7 of 7
Re: Broadband speed
Thanks Paultechy will arrange for a tech visit.
