  • 6
surajid
Broadband speed
My package was 100 mbps but Broadband in my house was approx 35mbps. Then I upgraded a month ago to 200mbps but still 35 mbps all 24/7.
I have 3 devices running maximum at a time.
How do I reset the HUB to factory setting?
or Where do I call to book engineer for this problem?
  • 5.65K
  • 290
  • 1.25K
Re: Broadband speed
Is this wireless speeds? Or are they wired tests?
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 6
surajid
Re: Broadband speed
it
It is wireless test.
  • 22.23K
  • 845
  • 3.23K
Re: Broadband speed
you will need to test the speed using a wired connection to the hub.
35 may be a limit of the wireless cards you are using
