  • 7
Ginge
Broadband speed not what it should be
Hi,  I've run a couple of tests against speedtest.net and my BB speed in maxing out at around 90Mbps when it should be nearer 200Mbps.  Can somebody please look into this for me?
Cheers,
Mark.
Helpful Answers
  • 5.68K
  • 291
  • 1.25K
Re: Broadband speed not what it should be
To add to jb66, 90Mbs is a common hardware bottleneck. You need full gigabit equipment to get speeds above 90Mbs.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
All Replies
  • 8.64K
  • 440
  • 1.03K
jb66
Have you checked to see if your computer can handle more than 90?
  • 5.68K
  • 291
  • 1.25K
  • 7
Ginge
Hey folks, thanks to me having to bypass my gigabit switch due to my new pup chewing through the power cable I'm now going direct into my PC from the router and have 200Mbs speeds so good shout all.  Looks like there was something not quite right with the switch.
Thanks all for the steer.
