jimdoc
Broadband speed is low
My broadband  speed package is for up to 70mbs but speed checks show I am  getting less than 30 and that others in the area are getting much more.
  • 16.48K
  • 1.37K
  • 3.36K
Re: Broadband speed is low
hiya @jimdoc how are you testing your broadband wired/wireless?, if its via wireless can you test it via wired
