  • 9
djheaps
Broadband running at half speed - 90Mb/s rather than 200Mb/s
I have a 200Mb broadband package and I used to be able to get download speeds reliably around this figure until the end of May. However, since then the maximum speed I can get is around 90Mb/s.  Upload speeds are consistently OK, around 12Mb/s
Speedtest results are as shown below. I have also verified these speeds using thinkbroadband.com. All tests carried out with the same configuration using a hard-wired Ethernet cable from the router with the Superhub in modem mode.
IP_ADDRESS TEST_DATE TIME_ZONE DOWNLOAD
MEGABITS
UPLOAD
MEGABITS
LATENCY
MS
SERVER
NAME
DISTANCE
MILES
removed  25-Mar-17 18:31 GMT 219.9 12.32 12 London 0
removed  25-Mar-17 18:32 GMT 212.24 12.45 12 London 0
removed  25-Mar-17 18:33 GMT 214.91 12.34 12 London 0
removed  25-Mar-17 18:38 GMT 211.48 12.33 12 London 0
removed  25-Mar-17 18:41 GMT 215.72 12.34 13 London 0
removed  25-Mar-17 18:42 GMT 223.04 12.13 12 London 0
removed  25-Mar-17 18:43 GMT 220.95 12.44 13 London 0
removed  25-Mar-17 23:44 GMT 218.72 12.44 12 London 0
removed  07-Apr-17 10:09 GMT 217.53 12.41 10 London 0
removed  10-May-17 17:42 GMT 243.62 12.36 12 London 0
removed  12-Jul-17 12:07 GMT 89.36 12.3 10 London 0
removed  12-Jul-17 12:08 GMT 89.4 12.39 11 London 0
removed  12-Jul-17 12:24 GMT 91.55 12.33 11 London 0
removed  17-Jul-17 17:23 GMT 80.78 12.28 12 London 0
removed  17-Jul-17 17:54 GMT 81.98 12.15 11 London 0
removed  18-Jul-17 10:16 GMT 87.25 12.03 11 London 0
removed  25-Jul-17 13:31 GMT 91.65 12.18 12 London 0
removed  04-Sep-17 22:15 GMT 91.04 12.46 13 London 0
removed  13-Sep-17 15:10 GMT 94.42 12.38 12 London 0
I had a similar problem earlier in the year which I resolved by switching off the Superhub for around 5 mins and then powering up. I have tried that again 2-3 times but it makes no difference. [Note that even when I turn the Superhub back on after 10 minutes it appears to be immediately 'ready' - with the blue tick illuminated, i.e. it doesn't see to go through the power-up sequence with flashing lights that I would expect as it tries to establish a signal]
As far as I can tell the Downstream/Upstream stats look OK as per below.
Nothing has changed in the configuration at my end so I assume the problem must be somewhere in the Virgin Media network.
Downstream Status
  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 266750000 274750000 282750000 290750000 298750000 306750000 314750000 322750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 9 10 11 12 13 14 15 16
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV) -0.04 -0.12 -0.06 -0.01 0.01 0.06 0.04 -0.03
RxMER (dB) 36.17 35.97 35.97 35.97 36.17 35.97 35.97 35.97
Pre RS Errors 630 547 342 328 301 302 327 968
Post RS Errors 288 283 296 298 286 291 303 951
Upstream Status
pstream   US-1 US-2 US-3 US-4
Channel Type N/A N/A 2.0 2.0
Channel ID N/A N/A 41 43
Frequency (Hz) N/A N/A 46200000 32600000
Ranging Status Other Other Success Success
Modulation N/A N/A 64QAM 64QAM
Symbol Rate (Sym/sec) N/A N/A 5120000 5120000
Mini-Slot Size N/A N/A 4 2
Power Level (dBmV) N/A N/A 48.25 46.75
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 0 0 0 0
T4 Timeouts 0 0 0 0
First Time Last Time Priority Error Number Description
13/09/2017 15:04:20 GMT 13/09/2017 15:04:20 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
12/09/2017 23:43:52 GMT 12/09/2017 23:43:52 GMT Error (4) 68000407 TOD established
12/09/2017 23:43:20 GMT 12/09/2017 23:43:20 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
12/09/2017 23:43:19 GMT 12/09/2017 23:43:19 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
12/09/2017 23:43:09 GMT 12/09/2017 23:43:09 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
12/09/2017 23:42:57 GMT 12/09/2017 23:42:57 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
12/09/2017 23:42:51 GMT 12/09/2017 23:42:51 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
12/09/2017 23:42:46 GMT 12/09/2017 23:42:46 GMT Notice (6) 84000510 Downstream Locked Successfully
12/09/2017 23:42:38 GMT 12/09/2017 23:42:38 GMT Critical (3) 68001101 TFTP Request Retries exceeded, CM unable to register
12/09/2017 23:42:38 GMT 12/09/2017 23:42:38 GMT Critical (3) 68000500 TFTP failed - Request sent - No Response
12/09/2017 23:42:07 GMT 12/09/2017 23:42:07 GMT Error (4) 68000407 TOD established
12/09/2017 23:41:23 GMT 12/09/2017 23:41:23 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
12/09/2017 23:41:17 GMT 12/09/2017 23:41:17 GMT Notice (6) 84000510 Downstream Locked Successfully
12/09/2017 23:41:09 GMT 12/09/2017 23:41:09 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
12/09/2017 23:40:18 GMT 12/09/2017 23:40:18 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
12/09/2017 23:40:18 GMT 12/09/2017 23:40:18 GMT Warning (5) 84020200 Lost MDD Timeout
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
Helpful Answers
  • 5.66K
  • 291
  • 1.25K
Re: Broadband running at half speed - 90Mb/s rather than 200Mb/s
You are being locked on to a 10/100 connection, and not a 10/100/1000 gigabit one which is needed for speeds over ~90Mbs.
Usual suspects are:
Ethernet cables (check for wear, try a different one)
Network driver settings.
Equipment not capable of gigabit (seems ruled out as you've had speeds above)
This is not something VM control, it's the connection between hub and PC running at 10/100.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
All Replies
  • 5.66K
  • 291
  • 1.25K
Usual suspects are:
  • 9
djheaps
Thanks Shafreya.
It turns out the Ethernet cable between the Superhub and the router was the culprit. Replaced with a brand new cable and now all is well.
Thanks for your help
