jasonbritton43
Broadband problems
Broadband speed is so slow supposed to have a 200 but only running slow I can not download anything I done the the test and it saying no problem so really need help not happy
  • 7.39K
  • 316
  • 524
Re: Broadband problems
Hi jasonbritton43,
Thanks for posting!
Really sorry to hear you're having speed issues.
I've located your account and I can see an issue with the network in your area affecting speeds at peak times - Ref.(F004832061). Our technicians are working to get this sorted as soon as possible and have set a review date of 15th February.
I've also picked up an issue with your Downstream Power levels that will need to be adjusted by a technician. I've sent you a private message (purple envelope at the top right of your screen) so I can arrange an appointment.
Look forward to hearing from you! Smiley Very Happy
Josh
