Mozzarilla
Broadband keeps dropping out - Very Annoying
Over the last few weeks my broadband connection keeps dropping out.  It happens through out the day, on numerous occasions, lasting for a few mins each time.
This is very frustrating as I work from home a lot and have to keep reconnecting to my companies VPN system each time it happens!
I live in the OX12 area.
Neil
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Re: Broadband keeps dropping out - Very Annoying
Hi Mozzarilla,
Thank you for taking the time to post about your issues with your intermittent broadband connection, this can be frustrating I know so apologies for any inconvenience.
I have tested the connection from this end and I didn't see anything out of the ordinary! No errors or time outs inside the Hubs logs and all of the power levels are within the preferred range.
How are you connecting, wired or wireless?
What do the lights on the Hub indicate when the connection drops?
Could you please respond to me here with a recent copy of your Hubs logs for me to compare with the data we have here. You can find these by opening your internet browser and typing 192.168.0.1 into the address bar, in the top right hand corner before logging in it will say 'Router Status' click there and all the information needed is inside.
Take care,
Adam.
Mozzarilla
Hi Adam,
Recent network log below.
Most of our devices are on wireless.
First Time Last Time Priority Error Number Description
02/11/2016 18:35:47 GMT 02/11/2016 18:35:47 GMT Warning (5) 66050310 Auth Success - Web login successful.
02/11/2016 18:35:31 GMT 02/11/2016 18:35:31 GMT Warning (5) 66050300 Auth Fail - Web login failed.
02/11/2016 18:34:54 GMT 02/11/2016 18:34:54 GMT Warning (5) 66050300 Auth Fail - Web login failed.
31/10/2016 15:34:39 GMT 31/10/2016 15:34:39 GMT Error (4) 68010302 DHCP WAN IP -
31/10/2016 15:33:39 GMT 31/10/2016 15:33:39 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
31/10/2016 07:10:51 GMT 31/10/2016 07:10:51 GMT Error (4) 68010302 DHCP WAN IP -
31/10/2016 07:09:47 GMT 31/10/2016 07:09:47 GMT Error (4) 68000407 TOD established
30/10/2016 11:34:00 GMT 30/10/2016 11:34:00 GMT Error (4) 68010400 DHCP REBIND WARNING - Field invalid in response
30/10/2016 11:33:05 GMT 30/10/2016 11:33:05 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
30/10/2016 11:32:12 GMT 30/10/2016 11:32:12 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
30/10/2016 11:30:26 GMT 30/10/2016 11:30:26 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
30/10/2016 11:26:56 GMT 30/10/2016 11:26:56 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
30/10/2016 11:19:54 GMT 30/10/2016 11:19:54 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
30/10/2016 11:05:50 GMT 30/10/2016 11:05:50 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
30/10/2016 10:37:41 GMT 30/10/2016 10:37:41 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
30/10/2016 09:41:22 GMT 30/10/2016 09:41:22 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
30/10/2016 07:48:48 GMT 30/10/2016 07:48:48 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
30/10/2016 04:03:37 GMT 30/10/2016 04:03:37 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
 [MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 3.88K
  • 120
  • 203
Hi Mozzarilla,
Thanks for responding!
I appreciate you posting the copy of your Hubs logs! I've had another look and I can see a number of time outs inside each of your upstream channels, I would like to arrange for an engineer to attend and give the connection the once over and resolve this for you.
I will send you a PM (purple envelope at the top) detailing what's required to proceed with making the booking. Please respond to me there and I'll get this sorted for you.
Take care,
Adam.
