  • 14
Festwit
Message 1 of 18
Broadband Speed Slow
Hello all,
I am on Vivid200 speed after an upgrade last year. I posted at that time, saying speeds were very slow, averaging around 50mbps and would only improve if I rebooted the modem and router, and then only for a while.
It was investigated and an engineer called who made adjustments at the road cabinet which made things better for a long time.
it seems recently that very similar conditions have returned (not sure if same thing or different, but similar conditions). I recognise that it is 'up to' and speeds do slow in busy periods, but when it it regularly around the 50 mark even at non peak, I would appreciate that t if you could investigate again to see if there are any issues such as before or other causes.
I look forward to your soonest response.
Thanks and regards
Tim
  • 22.27K
  • 853
  • 3.24K
Message 2 of 18
Re: Broadband Speed Slow
can you post the powerl evels from your shuperhub please
  • 14
Festwit
Message 3 of 18
Hello apcyberax,
Thanks for your quick reply.
I have logged into the super hub ac2, but as I currently use it in modem only mode, I can't see an option that would give me the power level
.It  similar to the previous occasion and they found them at VM their end I think.
Is there another way I can find them?
Thanks for your assistance
Regads
Tim
  • 22.27K
  • 853
  • 3.24K
Message 4 of 18
connect to http://192.168.100.1 dont log in but click the modem status button top right i think
  • 14
Festwit
Message 5 of 18
Thanks apcyberax,
can see them now (can't pretend to understand them though :-))
Here they are, left to right ddownstream ds1 to ds8
5.72.  7.14.  5.55.  6.98.  7.01.  5.98.   5.16.   4.86
upstream us1 to us4
41.25     NA    NA   44.75
Hope this helps :-)
regards
Tim
  • 22.27K
  • 853
  • 3.24K
Message 6 of 18
they look normal that is what Vm would of changed last time in the box. Might need to wait for VM to get to the post to check area usage and see if that might be the problem
  • 14
Festwit
Message 7 of 18
Ok I shall wait and see..
Many thanks for taking a look, much appreciated :-)
regards
Tim
  • 14
Festwit
Message 8 of 18
Hello VM,
Have had no reply from you to date.. I know you are all busy, but would appreciate your soonest response.
Speeds really are poor.. lucky if I get 30 at times..
Thanks and regards
Tim
  • 105
  • 14
boysim34
Dialled in
Message 9 of 18
I'm getting very slow bb as well
EXCELLENT
100000 Kbit/s
07.02.2017 - 13:21
119.155 Kbit/s download
EXCELLENT
4.929 Kbit/s upload
VERY GOOD
52 ms ping
GOOD
384 con/m connections
VERY SLOW
looks to be the connections
  • 8.37K
  • 362
  • 590
Message 10 of 18
Hi Festwit,
Welcome to the Community!
Really sorry to hear you've had trouble with your connection.
I can see you've spoken to our Webchat team about the issue. Have you been able to test with a wired connection to see if the speed improves?
Speak soon Smiley Very Happy
Josh
