  • 24
davey99
Broadband Fault Checker
Hi, I'm constantly getting this when performing a broadband self check :-
Is there actually anything wrong? As i do get slow speeds of an evening and wondering if there's still a contention issue in the area under this fault code F004147201.
Speeds yesterday where awful only getting between 7-12mbps.
Cheers in advance.
Dave
  • 8.32K
  • 361
  • 588
Re: Broadband Fault Checker
Hi davey99,
Thanks for posting!
really sorry to hear you're experiencing speed issues.
I've located you account and I can see an issue with the network in your area affecting speeds at peak times - Ref.(F004147201). Our technicians are working to fix this and have set a review date of 1st February.
I've also picked up an issue with your Downstream Power levels that will need to be adjusted by a technician. I've sent you a private message (purple envelope at the top right of your screen) so I can arrange an appointment.
Speak soon Smiley Very Happy
Josh
