  • 6
blaustrum72
Message 1 of 16
Broadband 150 - where is it?
Since getting the free upgrade I have run various speed tests and rarely get 150mbps...was this just an advertising gimmick? I am connected via ethernet cable to a Gigabit connected pc - any reason why I don't get 150mbps?
Helpful Answers
  • 5.37K
  • 273
  • 1.18K
Message 10 of 16
Re: Broadband 150 - where is it?
You might want to get a new Ethernet cable that's cat5e or better. It's a common bottleneck. (Although check it's not the ports on your computer/laptop first)
90Mbs is a common bottleneck for non gigabit speeds.
If you have a superhub1/2/2ac you can look at the colour of the Ethernet port. If it's green you good and it's something else, if it's yellow/Amber that's just showing something is limiting the connection to 10/100 not 10/100/1000 gigabit connection you need for above 90Mbs.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
All Replies
  • 2.62K
  • 209
  • 799
Dave_cq
Trouble shooter
Message 2 of 16
Just as a check, can you log into your hub and look at the Operation Configuration page and see what the Downstream Maximum Traffic Rate is quoting.
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
  • 6
blaustrum72
Message 3 of 16
Hi Dave, thanks for your reply - where would I find that info?
  • 6
blaustrum72
Message 4 of 16
found it Dave - it reads - 172500000 bps
  • 2.62K
  • 209
  • 799
Dave_cq
Trouble shooter
Message 5 of 16
In your browser of choice, Internet Explorer say, enter the URL  192.168.0.1  and it should take you to your Hub's login page but DO NOT log in ... just click on Router Status and you should see a menu of statistics options.
Electron
  • 2.62K
  • 209
  • 799
Dave_cq
Trouble shooter
Message 6 of 16
OK  that's a good start because now it's clear your service is set to a maximum of 172.5mbps so now we have to find out why you are not getting anywhere near that.
Same menu place ... can you copy and paste your Upload and Download statistics so that we can see if you have problematic power levels or noise levels.
Electron
  • 5.37K
  • 273
  • 1.18K
Message 7 of 16
What speeds are you actually getting as well?
  • 6
blaustrum72
Message 8 of 16
  • 6
blaustrum72
Message 9 of 16
90-95mbps usually
  • 5.37K
  • 273
  • 1.18K
Message 10 of 16
