tonydunn
Message 1 of 7
Bandwidth post-outage is poor
I suffered some outage last week (Thu/Fri) in Area 20, which removed access completely for about eight hours. Called support, did the usual turn it on and off again dance which fixed nothing, was told I’d get a call back in 30 minutes, which didn’t happen. Far from impressed by that, but I hear it's about par for the course.
Area fault was acknowledged (on Twitter) with expected resolution date of 03/04/2017. My broadband came back on the same day (so before the anticipated resolution date), so wild cheers all round, but…
My bandwidth now is never better than about 20 mbps, which is pretty poor when you consider I’m paying for 150 mbps. What’s the score VM? Anyone else seen this drop-off in performance after last week's issues?
  • 10.82K
  • 308
  • 632
Message 2 of 7
Re: Bandwidth post-outage is poor
Hi tonydunn,
Thanks for posting and a warm welcome to the community.
My apologies you are having an issue with the broadband connection.
I've managed to locate your account and there is a high peak time traffic fault in your area which is causing slow speeds. The reference number is F004954502 and has a review date of 4th October.
Do you notice these speeds at all times of the day or just during peak hours?
Were the speed tests you completed through a wired or wireless connection?
Look forward to hearing from you
Sam
  • 770
  • 14
  • 120
tommey
Well-informed
Message 3 of 7
Have you rebooted your superhub?
I would love to see your hub stats you can do this by entering 192.168.0.1 in a web browser no need to log in just click the link underneath the big red next button on hub 3 or top left on hub 2, then copy and paste the upstream and downstream stats
we should be able to see whats happening from those, because even if you are in an oversold / over utilised area you should see above 20 meg before 4pm / after 1am
This is the poor quality of my Superhub 3 connection Smiley Sad
My Broadband Ping - Vivid 200 Gamer
- First reported 09/2014 - Fault ticket raised 01/01/15 -    - Review 01/05/15 - Review 12/08/15 - Review 14/10/15 - Review 04/11/15 - Review 15/04/16 - Review 06/07/16 - Review 31/09/16 - Review 30/11/16 - Review 15/02/17 - Review 12/07/17 - Review 20/09/17 - Review 14/06/17 - Review 10/01/18 - Review 25/04/18 - F004670584 << 3 YEARS+
But with BT Fibre I can actually game without lag Smiley Very Happy
My Broadband Ping - BT FIBRE 80/20
tonydunn
Message 4 of 7
Hello Sam
The time of day doesn't seem to be having an effect, but whether or  not the device is wired or wireless most certainly does. I ran the Ookla speed test today using my wired iMac, and I was getting upwards of 165 mbps around 15:00. I ran the identical test on a wirelessly connected MacBook Air, and best I got was around the 20 mbps mark. Tried again this evening, with very similar results. I reckon it's the router that's the issue - would you agree that's most likely?
I've never been happy with the Super Hub we have. It regularly decides the login password is incorrect for any device trying to connect, and needs a reboot to allow logins, even when the password is actually correct. It frequently drops connection to the Internet, and has to be re-started every few days. I've put up with it this far, but I think I'll ask for a replacement. I've tried tweaking the settings for channel etc, but with no real effect.
Thanks for your help.
Tony
tonydunn
Message 5 of 7
Have I? Hell yes. I'm sick to death of rebooting the piece of junk, it's all I ever do with it. See my reply to Sam, wired works great, wireless is lousy.
Downstream
DS-1
DS-2
DS-3
DS-4
DS-5
DS-6
DS-7
DS-8
Frequency (Hz)
202750000
170750000
178750000
186750000
194750000
210750000
218750000
226750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Channel ID
5
1
2
3
4
6
7
8
Modulation
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
Symbol Rate (Msym/sec)
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
Interleave Depth
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)
-3.87
-3.48
-3.36
-3.37
-3.66
-4.16
-4.52
-4.87
RxMER (dB)
37.94
37.94
37.94
37.94
38.26
37.94
37.64
37.36
Pre RS Errors
1020
1666
796
1490
610
520
449
455
Post RS Errors
316
306
325
1076
318
302
280
287
Upstream
US-1
US-2
US-3
US-4
Channel Type
N/A
N/A
2.0
2.0
Channel ID
N/A
N/A
1
2
Frequency (Hz)
N/A
N/A
46200000
39400000
Ranging Status
Other
Other
Success
Success
Modulation
N/A
N/A
64QAM
64QAM
Symbol Rate (Sym/sec)
N/A
N/A
5120000
5120000
Mini-Slot Size
N/A
N/A
4
4
Power Level (dBmV)
N/A
N/A
46.00
45.50
T1 Timeouts
0
0
0
0
T2 Timeouts
0
0
0
0
T3 Timeouts
0
0
0
0
T4 Timeouts
0
0
0
0
Regards,
Tony
  • 10.82K
  • 308
  • 632
Message 6 of 7
Hiya tonydunn,
Thanks for getting back to me.
In regards to the router disconnecting and having an issue with connecting devices, complete a factory reset from within the router (be mindful that any saved settings will revert to default) to see if that will help.
You can also try to change the wireless channel to see if that improves the connection, as there could be interference within the property that is causing an issue.
Is there a difference in speeds between the 2.4 GHz and the 5 GHz network?
Speak soon
Sam
tonydunn
Message 7 of 7
Hi Sam
Just performed a factory re-set and I'm now getting speeds over wireless greater than 150 mbps on all the devices connected. Many thanks for your time and suggestions, happy to be getting proper performance again, can only hope that it lasts!
Regards,
Tony
