  • 7
MichaelJF80
Message 1 of 15
BB speed nowhere near 100MB
Evening,
Apologies in advance for complaining haha.
I've signed up for the 100VIVID 100MB broadband, and, well, it's not going great. At off peak times, the download speed is hovering somewhere between 30-35MB, which, isn't really good enough.
Some help/advice would be greatly appreciated. Thanks.
Helpful Answers
  • 9.36K
  • 801
  • 1.96K
Message 4 of 15
Re: BB speed nowhere near 100MB
It would be worth spending a couple of quid to get one. 35Mbps is a typical wifi speed on a single stream wireless device on the 2.4Ghz band, using a single channel.
Without testing wired it would be hard to tell if the problem is with VM's internet supply or with the wireless.
What device are you testing with?
All Replies
  • 9.36K
  • 801
  • 1.96K
Message 2 of 15
How are you connecting wired or wirelessly?
If wireless, try wired directly to the hub with a Cat 5e or better ethernet cable
  • 7
MichaelJF80
Message 3 of 15
wireless.
(possibly stupidly) I don't have an ethernet cable.
  • 9.36K
  • 801
  • 1.96K
Message 4 of 15
  • 7
MichaelJF80
Message 5 of 15
So, without wishing to sound idiotic, is the 'up to' 100MB the sort of speed that you can only expect from an ethernet connection?
I've been using Ookla to test the speed.
  • 111
  • 8
  • 39
voicon
Up to speed
Message 6 of 15
You can get 100mb on the right wireless system as well but wireless has many determining factors that will reduce the speed, wired is less complex.
Do you know what wifi card you have or the model of your laptop?
  • 7
MichaelJF80
Message 7 of 15
Dell Inspiron 13 5000 core i5 7200. Apologies not sure what wireless card I have.
  • 111
  • 8
  • 39
voicon
Up to speed
Message 8 of 15
That laptop is more than capable of 100mb on wireless, did you connect to the 2.4 or 5ghz wireless when you connected?
  • 7
MichaelJF80
Message 9 of 15
keeps fluctuating between the two. Right now, it says '2.4'. When I check the frequency. The day I first connected, it was saying 5.
  • 7
MichaelJF80
Message 10 of 15
Out of curiosity, does anyone know, or recommend what to adjust the hub's wireless settings to, so they're optimal? Which channels work best, etc?
Thanks.
