Charax
Area 24 Latency issue
Hi Guys
So over the past few weeks I've noticed that webpages will just stop loading and need to be refreshed to finish, it's been a minor annoyance but its been happening more and more frequently, and now its starting to cause issues (gf ended up double-paying for something - luckily the bank stopped it - and my Internet banking authentication fails, but works fine over 4G from my phone)
I've been running a Broadband Quality Monitor for the last day or so and that seems to show that the issue is frequent, but not consistent, latency. Router reboots don't seem to have an effect (I'll try later today and see if the graph changes)
My Broadband Ping - VM Connection 4/4/17Worth noting that for almost the entirety of this test I was at work or asleep, so these are happening independent of usage, and aside from some blips around 4:30pm there doesn't seem to be significant packet loss, but it's still highly disruptive (I can forget about gaming and most media streaming is out of the question, reducing my Vivid 152 Optical Fibre package to basic web browsing and some Youtube if I'm lucky.
Router status info:
Cable Modem EuroDOCSIS 3.0 Compliant
Boot Code Version PSPU-Boot 1.0.20.1356
Software Version V1.01.33
Hardware Version 3.11
Acquired Downstream Channel (Hz) 259000000 Locked
Ranged Upstream Channel (Hz) 39400000 Success
Provisioning State OK Operational
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)259000000235000000243000000251000000267000000275000000283000000291000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID1613141517181920
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)5.145.644.964.645.105.365.275.12
RxMER (dB)39.8539.4038.6138.6139.8540.3739.8539.85
Pre RS Errors11098152831197554209443153121017
Post RS Errors2913002913079373042951000
Upstream   US-1 US-2 US-3 US-4
Channel Type2.0N/AN/A2.0
Channel ID42N/AN/A43
Frequency (Hz)39400000N/AN/A32600000
Ranging StatusSuccessOtherOtherSuccess
Modulation64QAMN/AN/A64QAM
Symbol Rate (Sym/sec)5120000N/AN/A5120000
Mini-Slot Size4N/AN/A4
Power Level (dBmV)44.50N/AN/A44.25
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts4000
T4 Timeouts0000
Network Log:
First TimeLast TimePriorityError NumberDescription
05/04/2017 06:57:18 GMT05/04/2017 06:57:18 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
04/04/2017 09:23:58 GMT04/04/2017 09:23:58 GMTCritical (3)82000200No Ranging Response received - T3 time-out
04/04/2017 07:32:30 GMT04/04/2017 07:32:30 GMTWarning (5)66050310Auth Success - Web login successful.
04/04/2017 07:10:42 GMT04/04/2017 07:10:42 GMTWarning (5)66050310Auth Success - Web login successful.
01/04/2017 16:42:02 GMT01/04/2017 16:42:02 GMTError (4)68010302DHCP WAN IP - 81.105.28.66
01/04/2017 16:40:53 GMT01/04/2017 16:40:53 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedCritical (3)82000200No Ranging Response received - T3 time-out
Time Not EstablishedTime Not EstablishedNotice (6)84000510Downstream Locked Successfully
Is this the Hertfordshire overutilisation fault mentioned in this thread, or something different?
  • 10.59K
  • 311
  • 653
Re: Area 24 Latency issue
Hello there Charax,
Thanks for joining the community Smiley Very Happy
Really sorry to see the problems with your connection, I appreciate the testing you've done so far. I've taken a look from our end and I don't see anything obviously wrong right now. Are you able to monitor the performance of your network with your Hub in Modem Mode?
Hope to hear back from you again soon,
Take care.
Heather_J
Charax
Hi Heather, thanks for responding!
I didn't put the router in Modem mode as it seems to be returning to a quasi-usable state, also seems to be a regional thing as another VM user a street over is experiencing exactly the same thing, if the issue recurs (or rather, worsens, the graph seems to indicate lag spikes are just going to be a fact of life for me now) then I will continue the diagnostics in modem mode
