joeleo81
Area 22 - Intermittent Network Speed
Hi Guys,
Having an issue with my broadband connection at the moment. Currently on the 200Mbps package however I am seeing intermittent issues where I get less than 1Mbps
Using SpeedTest to check and results I've had
24/10 17.34 D/Load - 75.98 Upload 8.56 Ping 36
24/10 05:40 D/Load - 0.07 Upload 12.20 Ping 34
24/10 05:37 D/Load - 0.19 Upload 12.62 Ping 34
I can see in the Network Log lots of Lost MDD Timeout messages. I've tried:
  • clearing the logs.
  • hard reboot.
  • factory reset
All to no avail and this appears to be so intermittent. Hub I have is a Superhub 2ac.
Details from the status pages below:
Any help appreciated.
First Time Last Time Priority Error Number Description
25/10/2016 05:28:17 GMT 25/10/2016 05:28:17 GMT Warning (5) 84020200 Lost MDD Timeout
25/10/2016 05:28:13 GMT 25/10/2016 05:28:13 GMT Warning (5) 84020200 Lost MDD Timeout
25/10/2016 05:28:09 GMT 25/10/2016 05:28:09 GMT Warning (5) 84020200 Lost MDD Timeout
25/10/2016 05:27:57 GMT 25/10/2016 05:27:57 GMT Warning (5) 84020200 Lost MDD Timeout
25/10/2016 05:27:55 GMT 25/10/2016 05:27:55 GMT Warning (5) 84020200 Lost MDD Timeout
25/10/2016 05:27:53 GMT 25/10/2016 05:27:53 GMT Warning (5) 84020200 Lost MDD Timeout
25/10/2016 05:27:43 GMT 25/10/2016 05:27:43 GMT Warning (5) 84020200 Lost MDD Timeout
25/10/2016 05:27:39 GMT 25/10/2016 05:27:39 GMT Warning (5) 84020200 Lost MDD Timeout
25/10/2016 05:27:33 GMT 25/10/2016 05:27:33 GMT Warning (5) 84020200 Lost MDD Timeout
25/10/2016 05:27:31 GMT 25/10/2016 05:27:31 GMT Warning (5) 84020200 Lost MDD Timeout
Downstream
  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 298750000 266750000 274750000 282750000 290750000 306750000 314750000 322750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 105 101 102 103 104 106 107 108
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12 J=17 I=12 J=17 I=12 J=17 I=12 J=17 I=12 J=17 I=12 J=17 I=12 J=17 I=12 J=17
Power Level (dBmV) 6.94 7.01 6.87 6.95 7.00 6.87 6.62 6.60
RxMER (dB) 27.75 28.26 28.03 28.03 27.84 27.64 27.47 27.41
Pre RS Errors 57886788 57421853 57695878 57695177 57803357 57921981 57957111 57966151
Post RS Errors 5900643 664790 1680166 1581767 2939459 8058269 14973007 17659762
Upstream
  US-1 US-2 US-3 US-4
Channel Type N/A N/A 2.0 2.0
Channel ID N/A N/A 5 6
Frequency (Hz) N/A N/A 46200000 39400000
Ranging Status Other Other Success Success
Modulation N/A N/A 16QAM 16QAM
Symbol Rate (Sym/sec) N/A N/A 5120000 5120000
Mini-Slot Size N/A N/A 4 4
Power Level (dBmV) N/A N/A 41.50 40.50
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 0 0 0 1
T4 Timeouts 0 0 0 0
  • 16.11K
  • 1.34K
  • 3.27K
Re: Area 22 - Intermittent Network Speed
hiya @joeleo81 welcome to the virginmedia community forum, your upstream signals are showing fine, but major issue with the downstream SnR showing far too low, this more than likely require a tech visit to see what is going on, it will be around a week or less for the forum admin to reply, or you could contact broadband support via 150 / 0345 454 1111 (advising them to check the downstream SnR).. if you contact support can you post the outcome here.
  • 9.98K
  • 292
  • 624
Hey joeleo81,
Thank you for posting and welcome to the community Smiley Very Happy
I'm sorry to hear that you're experiencing an intermittent connection, thanks for proving your stats.
I agree that your SNR could do with being looked at. Let's get an engineer out to take a look.
I'll send you the appointment info via PM (purple envelope, top right).
Speak with you very soon,
Take care.
Heather_J
