  • 10
GamerCub
Area 21 Speed low so low!
What is going on with the Area 21 speeds in the past few weeks!
My internet from at least half 3pm, goes so low that it almost just as bad ADSL+2! What it is going on with my connection, for the past 4/5 hours its been so low. When I am on the meant to be on the so called "150mb" service!
Now for technical questions. I would ring up customers services. However they are just as bad and just follow a simple set of rules when I am telling them the problem and freak out.
I am wired connected to the Superhub 2ac, using a Cat6 cable (which I changed to make sure its not the cable). I have removed all other internet items that using it, via cable/wireless still has not made a difference at all! So Virgin Media is so quick to put the price up but yet offer slower speeds/rubbish customer services. When my your self work in the IT section and I tell them what maybe the problem/problem is and they do not believe you what the problem is.
  • 10
GamerCub
Re: Area 21 Speed low so low!
1am and now internet is still so low!
  • 10
GamerCub
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)298750000266750000274750000282750000290750000306750000314750000322750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID6561626364666768
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)-2.59-3.05-2.97-3.00-2.90-2.51-2.64-2.50
RxMER (dB)37.9437.0937.0936.8437.9437.9437.6438.26
Pre RS Errors621563363356350314315316
Post RS Errors297308285300317312314316
Upstream   US-1 US-2 US-3 US-4
Channel TypeN/AN/A2.02.0
Channel IDN/AN/A13
Frequency (Hz)N/AN/A4620000032600000
Ranging StatusOtherOtherSuccessSuccess
ModulationN/AN/A64QAM64QAM
Symbol Rate (Sym/sec)N/AN/A51200005120000
Mini-Slot SizeN/AN/A44
Power Level (dBmV)N/AN/A49.0049.00
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
  • 12.48K
  • 353
  • 1.45K
Hi GamerCub,
Apologies for your poor speeds - I shall do all I can to help with this. Thank you too for saving time by trying a new Cat6 and disconnecting other devices Smiley Happy
Your Hub's posted power levels are fine and are pretty much the same in the tests I've just run. I can find no network errors or dipped SNR on the upstream segment to which you connect and there is definitely no issue with peak time congestion.
This leads me to believe that there may perhaps be a problem with the Hub itself. Would you perform a full factory reset please? If there is no improvement after that please run a couple of speed tests via speedtest.net and post the results on here. It might also be a good idea to run a BQM and post that output on here too. these results would be helpful in diagnosing any potential network related issues.
My thoughts are leaning to a replacement Hub but I'll wait for your reply first Smiley Happy
Jen
