  • 29
kukky
Message 1 of 15
After update to VIVID 150 Optical Fibre
Hi, After update from VIVID 100 to VIVID 150, I have some problems with download speed. It's dropping down to 15mb/s. Can you please take a look is it any problem around my area? Postcode: PO1 4HY, area: 20. I think, I can still back to VIVID 100 if it's going to help me. I never had any problems before update. Can you let me know ASAP please.
  • 29
kukky
Message 2 of 15
Re: After update to VIVID 150 Optical Fibre
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)234750000242750000250750000258750000266750000274750000282750000290750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID12345678
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)2.282.292.202.032.042.272.212.05
RxMER (dB)37.3637.6437.9437.6438.2638.2637.9438.26
Pre RS Errors668151346910941120343352991
Post RS Errors3022953049641027275290918
  • 29
kukky
Message 3 of 15
Upstream   US-1 US-2 US-3 US-4
Channel Type2.0N/AN/A2.0
Channel ID2N/AN/A1
Frequency (Hz)39400000N/AN/A46200000
Ranging StatusSuccessOtherOtherSuccess
Modulation64QAMN/AN/A64QAM
Symbol Rate (Sym/sec)5120000N/AN/A5120000
Mini-Slot Size4N/AN/A4
Power Level (dBmV)45.25N/AN/A45.50
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts1000
  • 29
kukky
Message 4 of 15
Any update?
  • 5.63K
  • 287
  • 1.24K
Message 5 of 15
VM reply to posts in oldest date order. Every time you reply you are put to the back of the queue. The current response time is 1-2 weeks from last post by you on your thread.
If you require a quicker reply (although not always correct/good) then you can battle through the phone staff scripts. They will likely promise you a fix date but it will only be a review date. Their scripts call them fix dates.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 10.82K
  • 308
  • 632
Message 6 of 15
Hi there kukky,
Thanks for posting back on the community.
Sorry to read that you are having issues with the broadband speeds.
When I checked your connection, there is a high peak time traffic fault in your area which is causing slow speeds. Our networks team are investigating the problem and are improving bandwidth and performance to help with this issue. The reference number is F004171411 and with a review date of 1st March 2017.
As this will effect your broadband during peak hours, do you notice the slow speeds outside these hours?
Hope to hear from you soon
Sam
  • 29
kukky
Message 7 of 15
I think 00:30 is outside of peak time and my speed is.. 53 mb/s
http://www.speedtest.net/my-result/5880103464
I also spoke to customer service about this and been told that I will get any recompense because of this, but nothing was added to my accout yet. When it may happen?
  • 5.63K
  • 287
  • 1.24K
Message 8 of 15
Peak times vary by location. Student locations see peak times into further hours of night for example.
  • 29
kukky
Message 9 of 15
I still have speed below 100 mb/s, even now my speed is 60mb/s on ethernet cable.
  • 10.58K
  • 311
  • 653
Message 10 of 15
Hey there kukky,
Thanks for getting back to us Smiley Happy
Apologies again about the fault in your area, I know it's disappointing.
As Samantha has said, the fault will be reviewed in March, but in the time being please keep in touch and let us know if you have any other questions.
When the fault is reviewed in March we will have much more info to share.
I appreciate your patience,
Take care.
Heather_J
