  • 785
  • 14
  • 123
tommey
Well-informed
Message 1 of 730
Advice please poor signal and slow speeds stats inside
Downstream Channels Lock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked 1 267000000 Hz 256 QAM 7.3 dBmV 37.9 dB 75461 3839
Locked 2 275000000 Hz 256 QAM 7.7 dBmV 38.3 dB 213013 5889
Locked 3 283000000 Hz 256 QAM 7.7 dBmV 38.3 dB 407847 49729
Locked 4 291000000 Hz 256 QAM 7.3 dBmV 37.4 dB 19869 9632
Locked 5 299000000 Hz 256 QAM 1.4 dBmV 24.1 dB 385325 384880
Locked 6 307000000 Hz 256 QAM -2.2 dBmV 31.2 dB 48161897 4730502
Locked 7 315000000 Hz 256 QAM 2.5 dBmV 36.8 dB 62485762 4992148
Locked 8 323000000 Hz 256 QAM 4.0 dBmV 37.6 dB 656749 83014
Upstream Channels
Lock Status Channel ID Frequency Modulation Tx Power Mode Channel Bandwidth Symbol Rate
Locked 61 37600000 Hz ATDMA 41.8 dBmV 16QAM 6400000 Hz 5120 Ksym/sec
NotLocked 0 0 Hz 0 dBmV 0 Ksym/sec
Locked 62 31000000 Hz ATDMA 40.5 dBmV 16QAM 6400000 Hz 5120 Ksym/sec
Speedtest
http://www.speedtest.net/result/3971575931.png
Half hour later I get this
http://www.speedtest.net/result/3971643598.png
very weird also seeing packetloss :/
This is the poor quality of my Superhub 3 connection Smiley Sad
My Broadband Ping - Vivid 200 Gamer
- First reported 09/2014 - Fault ticket raised 01/01/15 -    - Review 01/05/15 - Review 12/08/15 - Review 14/10/15 - Review 04/11/15 - Review 15/04/16 - Review 06/07/16 - Review 31/09/16 - Review 30/11/16 - Review 15/02/17 - Review 12/07/17 - Review 20/09/17 - Review 14/06/17 - Review 10/01/18 - Review 25/04/18 - F004670584 << 3 YEARS+
But with BT Fibre I can actually game without lag Smiley Very Happy
My Broadband Ping - BT FIBRE 80/20
  • 785
  • 14
  • 123
tommey
Well-informed
Message 2 of 730
Re: Advice please poor signal and slow speeds stats inside
Downstream ChannelsLock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked1267000000 Hz256 QAM6.0 dBmV 37.9 dB1149613839
Locked2275000000 Hz256 QAM3.3 dBmV 36.0 dB63435517079
Locked3283000000 Hz256 QAM-3.5 dBmV 34.1 dB1303282182971
Locked4291000000 Hz256 QAM1.5 dBmV 35.6 dB9420664291303
Locked5299000000 Hz256 QAM3.9 dBmV 37.1 dB61745982010737
Locked6307000000 Hz256 QAM4.8 dBmV 37.6 dB588325264853134
Locked7315000000 Hz256 QAM4.9 dBmV 37.9 dB624858804992148
Locked8323000000 Hz256 QAM5.2 dBmV 37.9 dB65685283014
Upstream ChannelsLock Status Channel ID Frequency Modulation Tx Power Mode Channel Bandwidth Symbol Rate
Locked6137600000 HzATDMA41.8 dBmV16QAM6400000 Hz5120 Ksym/sec
NotLocked00 Hz 0 dBmV  0 Ksym/sec
Locked6231000000 HzATDMA40.5 dBmV16QAM6400000 Hz5120 Ksym/sec
As you can see the power levels are constantly changing sometimes I even lose 1 of the downstream channels and it just says not locked :/
My ThinkBroadband LIVE graph
http://www.thinkbroadband.com/ping/share-thumb/a2114bd0067deadf34368d1465cce625.png
  • 13.24K
  • 379
  • 1.09K
Moderator
Moderator
Message 3 of 730
Hi tommey,
Thanks for posting and apologies for the intermittent speed issues, I'm hoping these have settled down as checking your cable all looks to be in good health with the only issue the fairly wide spread in downstream power levels.
If you're still having any problem drop us a quick update along with the Hubs network logs so we can give these a quick check over and we'll gladly investigate further.
Cheers
Ralph_R
Forum Moderator
  • 785
  • 14
  • 123
tommey
Well-informed
Message 4 of 730
Hi Ralph_R
So what you are saying is my modem is running in its best state for optimal performance.
I beg to differ and would like it fixed please..
  • 785
  • 14
  • 123
tommey
Well-informed
Message 5 of 730
Locked5299000000 Hz256 QAM4.9 dBmV 37.6 dB65938286
Locked1267000000 Hz256 QAM-5.5 dBmV 30.0 dB229812983424310
Locked2275000000 Hz256 QAM0.9 dBmV 35.1 dB15161495257559
Locked3283000000 Hz256 QAM3.6 dBmV 37.1 dB5447368380
Locked4291000000 Hz256 QAM4.4 dBmV 37.4 dB527328
Locked6307000000 Hz256 QAM5.1 dBmV 37.9 dB615318
Locked7315000000 Hz256 QAM4.8 dBmV 37.9 dB653341
Locked8323000000 Hz256 QAM4.7 dBmV 37.9 dB1205974
Locked6231000000 HzATDMA41.8 dBmV16QAM6400000 Hz5120 Ksym/sec
Locked6137600000 HzATDMA43.0 dBmV16QAM6400000 Hz5120 Ksym/sec
Look at all the errors on 1-2-3-5  surely that's not optimal performance...
  • 16.69K
  • 1.4K
  • 3.42K
Message 6 of 730
yeah looking over your signal levels, your SNR is too low on the highlighted, and having all those Pre-rS errors, can you post the network log..does it show any faults via -> https://my.virginmedia.com/faults/service-status
  • 13.24K
  • 379
  • 1.09K
Moderator
Moderator
Message 7 of 730
Hi tommey,
Thanks for the update, though sorry to see that your connection problems remain ongoing, as I can't see any wider networks issues to explain the fluctuating SNR and climbing post RS errors then we'll to arrange for an engineer visit to investigate this locally with you.
I'll drop you a Private Message so we can get this booked in.
Ralph_R
Forum Moderator
  • 785
  • 14
  • 123
tommey
Well-informed
Message 8 of 730
Today's stats surely this is not normal I even have a channel that's not even locked :/
Locked5299000000 Hz256 QAM3.0 dBmV 36.6 dB169934286
Locked1267000000 Hz256 QAM7.3 dBmV 38.3 dB449532163643312
Locked2275000000 Hz256 QAM7.3 dBmV 37.9 dB20733708414881
Locked3283000000 Hz256 QAM3.3 dBmV 33.5 dB5917253378890
NotLocked  Unknown
Locked6307000000 Hz256 QAM4.6 dBmV 37.6 dB1015318
Locked7315000000 Hz256 QAM5.0 dBmV 37.9 dB1091341
Locked8323000000 Hz256 QAM5.5 dBmV 38.3 dB1499974
Locked6231000000 HzATDMA41.5 dBmV16QAM6400000 Hz5120 Ksym/sec
Locked6137600000 HzATDMA42.8 dBmV16QAM6400000 Hz5120 Ksym/sec
Hi thanks for the pm however I cannot see how or why I should take a day off work and lose around £100 to wait in for an engineer, surely this issue is elsewhere not at my property, would you not be able to remotely access my superhub to do any checks you need to do?
thanks
  • 785
  • 14
  • 123
tommey
Well-informed
Message 9 of 730
Network log requested by pailtechy
Date Time Error Number Error Description
26/12/201410:58:12 GMT84020200Lost MDD Timeout
  • 16.69K
  • 1.4K
  • 3.42K
Message 10 of 730
could be issue with cable into your property, so need somebody in to allow them access, or could be consider trespassing.. they could check the box first (cabinet), but then would need to book another engineer to visit your house etc.. so best to check it all in 1 go.
