  • 90
  • 8
bobajob84
Message 1 of 7
300mb to less than 20mb for 2 weeks now
I've had the same problem for 2 week's now after an engineer was in the area to fix a problem, i've had an engineer out at my house and he replaced the router, ethernet cable and the cable coming into the house and still nothing has fixed it.
Although i noticed the problem's seem to be HTTP, i've used Steam and other gaming clients to update games and i hit much better speeds but downloading anything on sites, using any speedtest or even trying to watch netflix/youtube it will buffer quite abit.
We have tried everything on my end and it's not my problem, we used different computers, browsers, wifi, router mode, modem mode, my own router and different cables.
I was told i would get a call on monday but obviously that didn't happen, i'm in contract now but i'm not going to continue to pay for bad service
  • 90
  • 8
bobajob84
Message 2 of 7
Re: 300mb to less than 20mb for 2 weeks now
Downstream bonded channels Channel Frequency(Hz) Power(dBmV) SNR(dB) Modulation Channel ID
1299000000-4.238.9256 qam21
2323000000-4.538.6256 qam24
3315000000-4.538.9256 qam23
4307000000-4.438.9256 qam22
5291000000-4.238.6256 qam20
6283000000-3.940.3256 qam19
7275000000-4.438.9256 qam18
8267000000-438.6256 qam17
9259000000-438.9256 qam16
10251000000-3.738.9256 qam15
11243000000-3.738.6256 qam14
12235000000-3.538.9256 qam13
Channel ID Frequency(Hz) Modulation Power(dBmV) Mode Channel Bandwidth(Hz) Symbol Rate (ksps)
5039400000ATDMA4616 qam64000005120
4946200000ATDMA47.316 qam64000005120
SFID44680
Max Traffic Rate12700000
Primary Upstream Service Flow
SFID43254
Max Traffic Rate220000000
Network Log Date And Time Error Number Event Description
2016-08-20 19:09:35.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:09:35.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:09:36.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:09:36.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:09:37.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:09:37.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:09:38.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:09:40.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:09:40.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:09:41.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:09:41.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:09:42.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:09:42.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:09:43.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:09:47.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:09:59.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-20 19:10:00.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-21 22:58:53.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 90
  • 8
bobajob84
Message 3 of 7
Promised a phone call on monday which didn't happen and was told i would get a phone call before 12 yesterday which didn't happen, i've tried 7 speedtests today and max speed is around 22mb.
I will hold out till it's been a month then i'm cancelling the direct debit.
PS again this is for HTTP
  • 5.94K
  • 159
  • 415
Message 4 of 7
Hi there bobajob84,
Thanks for posting and really sorry to hear about the problems with your broadband connection.
I've located your account and can see that we've discussed this with you further since posting.
I've also checked both the equipment and network segment and all looks to be okay at the moment.
Please let me know if there is anything more that I can help with.
Take care,
Nat_J
  • 90
  • 8
bobajob84
Message 5 of 7
Update!
I downgraded my connection back to 200mbit then spent another few weeks trying to get the speed fixed which they finally did fix and was nothing todo with my end.
Skip forward a few months and today i was offered the 300mbit line again at a cheaper price and it was turned on earlier and right away my speed dropped to below 47mbit with most servers saying under 12mbit.
Upload seem's fine, ping has also doubled now aswell.
What the hell is going on?
  • 90
  • 8
bobajob84
Message 6 of 7
Before i show they speedtest results that i done at 12:30am, today my speed was 216mbit out of 200mbit, i upgraded to 300mbit and now like last time i can even get 200mbit
Douglas Manx Telecom
40ms 10.84mbs 17.61mbs
Virgin Glasgow
16ms 20.58mbs 20.24mbs
Carlisle
Gemnini Group
31ms 69.32.mbps 20.15mbps
Preston BT
27ms 55.46mbps 20.14mbps
Dublin Vodafone
32ms 11.99mbps 20.15mbps
Manchester Virgin
13ms 22.98mbps 20.25mbps
Leeds AQ Limited
27ms 119.07mbps 20.25mbps
Sheffield XILO
28ms 20.46mbps 20.22mbps
Bristol Virgin
23ms 17.71mbps 20.26mbps
Telford Unitron Systems
31ms 94.62mbps 20.03mbps
Basildon Virgin
19ms 63.48mbps 20.28mbps
  • 5.94K
  • 159
  • 415
Message 7 of 7
Thanks for posting these results bobajob84,
I've responded to your private message so that we can talk some more about this.
Speak to you soon,
Nat_J
