  • 12
sgtbellpepper
300Mbps Homeworks+ Upload Speed
Hi all, I've recently had my services installed and so far I'm extremely happy with the ping and download speeds, which average 9ms and 310Mbps respectively.
The problem that I'm having is that my upload speed seems to be capped at 12Mbps, when I'm expecting close to 20Mbps. My average so far is between 10 and 11.8Mbps.
Please would someone advise what I need to do? Just to clarify, I've checked these speeds over Wi-Fi and Ethernet, in router and modem mode, directly via the SH3 and also via my Asus router, and the results are all the same.
Many thanks.
  • 362
  • 16
  • 83
pyrotenax
Fibre optic
Re: 300Mbps Homeworks+ Upload Speed
Can you post some speedtest results ...
http://www.speedtest.net
http://ovh.net
Running ASUS RT-AC88U with Asuswrt-Merlin firmware
  • 12
sgtbellpepper
Thanks for the reply.
Here is the requested info (I did both tests).
SPEEDTEST
OVH
  • 12
sgtbellpepper
Just a quick update. Super-impressed with the DL speed at 317Mbps ... but ... the UL speed, although slightly better, is still nowhere the 20Mbps it should be. Anyone care to offer any advice? Thanks.
5983294777
  • 362
  • 16
  • 83
pyrotenax
Fibre optic
How is it now ?
  • 12
sgtbellpepper
It's all good thanks.
