Srusty1962
20mb on 200mb Connection
Not here for a moan just after some technical guidance.  As the subject suggests I am currently only receiving on average 20mb on a 200mb service.  I have been running speed tests both wired and wireless and it never seems to peak above 20mb.
Any Ideas?
  • 10.82K
  • 308
  • 632
Re: 20mb on 200mb Connection
Hi Srusty1962,
Thanks for taking the time to post on the community.
My apologies you are not achieving the up to 200 Mbps broadband speeds.
I've run some tests on your connection, the line and hub have come back as fine. The network segment is running stable and healthy.
Are you able to complete speed tests whilst the Hub is in modem mode please? This will eliminate other devices connected. When using speedtest.net, make sure that the default server is selected and try to post a link/screenshot with the results please.
Let me know how you get on
Sam
Srusty1962
Hi Sam,
Apologies over my delay.  We ended up calling Virgin technical support and they did something and its now been resolved.
Cheers Smiley Very Happy
