  • 41
thekopno1
Message 21 of 34
Re: 300mb dropped to 20mb
Still no luck with this issue, I think I will call an engineer out. Such a pain in the ass as the Internet was working fine for well over a year.
I also have these error messages in the log for what's it worth:
-01-07 23:27:03.00 84000500 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:27:03.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:27:04.00 84000500 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:27:25.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:27:26.00 84000500 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:27:29.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:27:49.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:27:50.00 84000500 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:27:50.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:27:56.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:28:13.00 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:54:58.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:59:07.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:59:07.00 84000500 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:59:08.00 84000500 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:59:12.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-07 23:59:28.00 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-01-08 00:09:16.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 11.01K
  • 324
  • 670
Message 22 of 34
Hello thekopno1,
Thanks for getting in touch Smiley Happy
Sorry for your recent connection problems. I've just taken a look at your Hub and right now everything looks normal.
How have things been since your last post?
Take care.
Heather_J
  • 41
thekopno1
Message 23 of 34
Terrible. You keep saying that everything looks fine!
I made a phone call and the fault should be logged now?
Your colleague said the fibre cables may have a fault and a team of experts would need to come to my area.
Can you check the fault has been logged etc?
  • 41
thekopno1
Message 24 of 34
Also to add there are two fault logs in my hub, one is a synconisation failure and another I forget, but I posted them earlier.
There is definitely noise interference with your feed somewhere along the line.
  • 11.01K
  • 324
  • 670
Message 25 of 34
Hello again thekopno1,
Thanks for the additional info Smiley Happy
I've checked your account and I can see an engineer is visiting you on the 20th.
Please update us after the visit.
Take care.
Heather_J
  • 41
thekopno1
Message 26 of 34
The engineer came and replace the hub 3.
He did a speed test on his phone and showed me 250mb, so I was all happy, however I have just run a speed test and I'm getting only 20mb. Same speed test app as well. Very strange.
Engineer told me to contact him direct after a week to let him know of any issues.
I will do that..
  • 41
thekopno1
Message 27 of 34
Update
I have checked my phone on another network and I'm getting 300mbps so it's not my phone
. I have removed all my gadgets so just my phone on 5g but still 20mb. Last night I switched the channel to manual on 36,and behold I'm getting over 250mbps. Then today it's gone again back to 20mbps. I think this is a software fault with the hub 3. Could be a qos issue, but the hub 3 is showing an allocation of 1300mbps to my phone? My phone was fast as lightning browsing the net, its now slow, I'm getting a better speed from mobile net!
I'm just switched back the channel but this has no effect either (sometimes it does, sometimes it doesn't), taken out the Ethernet cable. No luck.
Maybe you can advise when a software update will be available to iron out these bugs?
  • 11.01K
  • 324
  • 670
Message 28 of 34
Hello thekopno1,
Thanks for the update Smiley Happy
Sorry that you're still having slow speeds. What are your hard-wired speeds like? Also, have you got back in touch with the tech at all?
Speak soon,
Take care.
Heather_J
  • 41
thekopno1
Message 29 of 34
Hard wired is fine. No I haven't been back in touch with the tech might send him a message.
  • 41
thekopno1
Message 30 of 34
Update.
Same thing seems to be happening once I wait a day and switch back to manual channel the speed increases then overnight back to square one.
This Is Almost certainly a software fault with the hub.
I have told the tech the same thing.
