RichardCoventry
200Mbps
Hello,
Help appreciated.
My package says I should be getting 200Mbps, but when I check on the Speedtest app I'm getting 1/2  that.
Is this common and can it be checked?
Regards, Richard
  • 8.4K
  • 413
  • 989
jb66
Re: 200Mbps
Depends what your testing it with. Many devices can't do 200meg
  • 10.82K
  • 308
  • 631
Re: 200Mbps
Evening RichardCoventry,
I'm sorry to read that you are not achieving the up to 200 Mbps broadband speeds.
You mentioned you completed the speed test on the app, was this through a phone or tablet?
If you can try through wired please, that will be helpful? On the laptop/PC you are testing with check to see if the LAN card is showing as a gigabit and the Ethernet cable is a Cat 5 e or above.
I checked your connection for any issues, the line and hub have come back as fine.
Let us know how you get on
Sam
