  • 57
tofu03141823
Message 1 of 56
200MB Fibre Optic Broadband speed/superhub problems
Hi mods and friends,
I am having problems with my 200Mb Fibre Optic broadband since the night of 24th February. The speed dropped drastically to 1-3Mbps according to speedtest.net
I have tried restarting the Superhub but the speed was still the same. I have been getting at least 170Mbps before with my WiFi and Wired connections. I don't know what the problem was.
I called the VM customer service and they tried to sort it out but didn't work.
The network log was displaying something weird like "Error 84000500 SYNC Timing Synchronization failure - Loss of Sync" which I know nothing about.
Please can anybody help.
See my speedtest below.
  • 9.68K
  • 674
  • 1.88K
Message 2 of 56
Re: 200MB Fibre Optic Broadband speed/superhub problems
are you testing wired or wireless - always test wired
log into superhub - 192.168.0.1 - DON'T SIGN IN, click router status - and post the downstream and upstream figures
____________________
Tony
  • 57
tofu03141823
Message 3 of 56
This was the wired speed test.
  • 16
booner99
Message 4 of 56
What area are you in area 04 is slow mine is rubbish on evening.
  • 57
tofu03141823
Message 5 of 56
I'm area 03. My net was never slow that's why i'm very concerned this is happening.
  • 9.68K
  • 674
  • 1.88K
Message 6 of 56
what SH is that - i thought 200 down needed a hub3 - may well be wrong - the levels look fine so that certainly looks like an external fault
@ModTeam - can someone have a look please - all looks fine but download is awful
Tony
  • 57
tofu03141823
Message 7 of 56
This one. No idea what superhub is this.
  • 10.95K
  • 238
  • 2.02K
Message 8 of 56
It's either SH2/VMDG485 or SH2AC/VMDG490 - Several clues/methods:
  • The "tally label' on underside will specify the exact VMDG4xx model
  • The gui (admin) homepage via 192.168.100.1 will display "Welcome to your Virgin Media Super Hub 2ac" so the "ac" (or absence thereof) might be a clue?
  • As well as Advanced Settings > . Wireless will only include 1300AC option for VMDG490......
  • The Software Version from 192.168.100.1 (Don't sign-in!!!!)  > Router Status (TOP RH corner) > Information > Software Version will display V1.01.11(or12) for SH2AC ....or  V1.01.29/31 . for SH2.....
Regards Tony
"Life is a Binary Inspired Turing Computed Hologram"(don't PM or @Mention me - in case ignoring you offends)
  • 57
tofu03141823
Message 9 of 56
Ah it says Super Hub VMDG485
Does that mean the vivid 200mb is not compatible with my superhub?
But even so, I shouldn't have this kind of speed as I was with 156mb previously before I upgraded in November 2016.
  • 10.95K
  • 238
  • 2.02K
Message 10 of 56
-tony- wrote:
..... - i thought 200 down needed a hub3 - may well be wrong -......
SH2/VMDG485 or SH2AC/VMDG490 can technically be configured with upto either V200 or V200Gamer.  That said what some of us still have via previous Trials/Speed Boosts does not neccessarily reflect what is now currently configured for defacto Residential Tiers.
(eg I personally only have V200 on SH2AC and V200Gamer on SH3 but as both Tiers have 230,000,000 and 230,470,000 bps D/S respectively then I suspect even the older SH2/VMDG485 will still pick up a V200 Tier)
However I'd expect with  the Homeworks 300  you may only find that deployed with a pre-req SH3/VMDG505  for those nodes with 16 - 24 D/S channels as load balancing (ergo utilisation/capacity) is far more efficient with a Hub capable of bonding (far greater) >>8 D/S channels!
Regards Tony
