  • 9
jsproule899
Message 1 of 14
200 mbps over wifi only 100mbps on gigabit ethernet
hello,
has anyone found the cause of this issue as I am currently experiencing it? on my desktop i have gigabit LAN port, cat 6 cable only getting max 110 Mbps, on the laptop with 866mpbs ac adapter getting 220 Mbps?
I was getting 160 Mbps previously through the same LAN port and same cables.
I have tried adding a dedicated PCIe Gigabit LAN port and 3 different cat 6 cables to no avail.
virgin media engineer called out and had no solution other than replacing router which did not fix the problem... the reason I pay for the 200mbps connection is for my computer not for any other device.
Helpful Answers
  • 9
jsproule899
Message 13 of 14
Re: 200 mbps over wifi only 100mbps on gigabit ethernet
..in hub3 connected devices it is showing a 1000Mbps connection
the network adapter is set to auto-negotiate
CPU usage is around 12% and nothing else is taking up bandwidth
I just ordered a USB 3.0-gigabit ethernet adapter for the laptop on amazon prime to test whether or not it is the computer limiting the connection
EDIT: Problem Solved, looks like it was 'System Mechanic' its auto-optimization of network settings must have been limiting it as you said... I would have thought of this soon but since it's been installed on my computer( as well as the laptop) for over a year now without affecting the speed ( was getting 160Mbps on 150Mbps package) I didn't suspect it.
hope this helps anyone else having this issue... thanks again for all the sugestions
All Replies
  • 10.02K
  • 332
  • 877
Hero
Message 2 of 14
Well its just odd you get max by wireless and not by wire and tried different cat 6 cables and added a dedicated PCIe Gigabit NIC.
So you have a PC and a laptop? Does your laptop have a 1Gb NIC to test.
maybe try a driver update
  • 9
jsproule899
Message 3 of 14
no, unfortunately, the laptop doesn't have a LAN port... might have to borrow a pc if I don't get a resolution
  • 10.02K
  • 332
  • 877
Hero
Message 4 of 14
are you trying your speed with this app?
http://www.speedtest.net/apps/desktop
  • 9
jsproule899
Message 5 of 14
yes I've been using speedtest.net
  • 57
  • 16
ToffeeSurprise
Dialled in
Message 6 of 14
Can you confirm the speed your network adapter is set / negotiating to?
In Windows this is found under Control Panel --> Network and Internet --> Network Connections. Alternatively search for network connections in the start menu.
Once you've found your adapter, double click on it. Speed should be 1.0Gbps.
  • 9
jsproule899
Message 7 of 14
  • 57
  • 16
ToffeeSurprise
Dialled in
Message 8 of 14
Not seeing an image of anything other than a triangle, if that's supposed to be a screenshot.
  • 9
jsproule899
Message 9 of 14
sorry yeah, it definitely is working at 1gbps
  • 3.02K
  • 91
  • 321
VMCopperUser
Problem sorter
Message 10 of 14
What Router are you using?  On the wired (Gigabit) device what OS are you using?
Is the device that connects at gigabit the ONLY device connected via wired ports?
Can you also confirm the device is connected directly (No Switches!).
If any other devices are connected then disconnect them, restart the router, test again.
Did you try one of the other ports on the router?
Some AV/Firewall Software can also cause issues such as slower than normal throughput.
I do not work for VM, but I would. It is just a Job.
I would also make websites for them, because the job never seems to require the website to work.
Read or Not ....
