  • 10
Nimbah101
Message 1 of 5
200 Gamer - Hub 2AC
Hi all,
upgraded to the 200 gamer package today and asked to keep my hub 2ac.
Just wondered if the below looked right? Looking at Mud Wizards guide I can see that my two upstreams can deliver around 50Mb max but just thought it was strange that they're set to different modulations
  • 10
Nimbah101
Message 2 of 5
Re: 200 Gamer - Hub 2AC
To add I am getting the correct speeds
  • 19
lajosnagy17
Message 3 of 5
Your modulation should be 64QAM on both.
  • 10
Nimbah101
Message 4 of 5
bump
  • 9.12K
  • 301
  • 981
Message 5 of 5
Hello Nimbah101
Thank you for the question. Both upstreams are performing well, the QAM32 25Mz channel is the default config for that channel on your cable by the way, there is plenty of capacity for the speed of your package.
Well pleased you are getting fast speeds.
Thank you
Nicola
Virgin Media Forum Team
