JaniceDepp
Message 1 of 9
150mb Broadband but only receiving 50mb speed
Hello, I recently got upgraded the broadband to 150 fibre optic (yesterday), but I'm still only receiving the speeds I got when I was on my last package (100) which is around 50-60. Do I need to have a new Super Hub sent? I still have the original Super Hub.
I've checked the configuration on the router status, it reads as;
Max Traffic Rate110100000 bps
Max Traffic Burst42600 bytes
Thanks. Smiley Happy
  • 8.62K
  • 438
  • 1.02K
jb66
Message 2 of 9
Re: 150mb Broadband but only receiving 50mb speed
50-60 is typical wireless speeds for 2.4ghz, you need a superhub 2 or greater to realistically achieve over 100 wireless
  • 5.65K
  • 290
  • 1.25K
Message 3 of 9
And/or devices that support above your current speeds. You may still be hitting your wireless ceiling.
Your upgrade hasn't gone through yet though, but if it's wireless it won't make a difference.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 8.62K
  • 438
  • 1.02K
jb66
Message 4 of 9
a SH1 cant do 150
JaniceDepp
Message 5 of 9
So, I'm guessing I need a new HUB then? Thanks for the replies.
  • 9.35K
  • 798
  • 1.96K
Message 6 of 9
Your configuration shows you are still on 100Mbps
You will need MIMO capable wireless devices to get 150Mbps wireless speeds, ideally 5Ghz capable, what devices are you using to connect wirelessly?
In theory the SH1 should be able to do round 150Mbps wirelessly as it uses two wireless stream (MIMO) and can support channel bonding to give a max Link speed of 300Mbps. However, the SH1 is a woefully underpowered device, so upgrading to a SH2 or SH2ac would be wise. You would also get simultaneous 2.4 Ghz and 5 Ghz bands.
  • 5.65K
  • 290
  • 1.25K
Message 7 of 9
VM won't provision a SH1 with the 150Mbs profile so it can't do 150 at all (it is capable though)
  • 10.64K
  • 313
  • 655
Message 8 of 9
Hey JaniceDepp,
Thanks for posting and a warm welcome to the community Smiley Very Happy
Sorry to hear about your slow speeds, I know it's disappointing when you don't receive the upgrade you're expecting.
I'll need to get new kit out to you, I'll drop you a PM (purple envelope, top right) to confirm your address.
Speak with you soon,
Take care.
Heather_J
JaniceDepp
Message 9 of 9
Thank you for the replies
