  • 5
MHess1
10% download speed after 18:30 area 01
No information on if the works that have been going on for over 2 years is gonna be pushed back or completed.
Unusable speeds after 18:30 can't use it to game and if more than one device is using the internet its horrendous.
2mb speed on a "20mb" line.
  • 5.35K
  • 272
  • 1.18K
Re: 10% download speed after 18:30 area 01
Are you on a superhub or a legacy router?
If you are not on a superhub it might be worth getting a free speed boost to 50/70Mbs so you can get a superhub and get 8 channels and not 1 channel to download from. Won't cure the over utilization but should alleviate it somewhat as more channels.
If already on superhub, ignore.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 10.82K
  • 308
  • 631
Hiya MHess1,
I appreciate you posting back on the community and apologies that you are experiencing slow broadband speeds.
I can see the high peak time traffic fault in your area which you mentioned. Our engineers are still working on this to improve bandwidth. The reference number is F004892579 and with a review date of 8th February 2017.
One of my colleagues will be in touch shortly with more information in regards to this.
Sam
