  • 37
kannanni
Message 1 of 7
timeouts - power levels on vivid 100
Hello,
using a black superhub 3 i noticed on the logs a few t3's on my 1 week old vivid 100 connection, can someone knowledgeable pls have a  look and tell me what you think:
 2017-02-24 09:59:33.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-24 10:53:18.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-24 18:18:12.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-25 02:36:54.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-25 05:03:32.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Upstream bonded channels Channel ID Frequency(Hz) Mode Power
7030200000ATDMA45.564 qam64000005120
6936800000ATDMA45.564 qam64000005120
Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
1 299000000 -0.9 38.6 256 qam 17
2 323000000 -1 38.6 256 qam 20
3 315000000 -1.4 38.6 256 qam 19
4 307000000 -1.2 38.9 256 qam 18
5 291000000 -1.5 38.6 256 qam 16
6 283000000 -1.9 38.9 256 qam 15
7 275000000 -1.7 38.6 256 qam 14
8 267000000 -1.7 38.9 256 qam 13
9 259000000 -1.9 38.6 256 qam 12
10 251000000 -2 38.9 256 qam 11
11 243000000 -2 38.9 256 qam 10
12 235000000 -2 38.9 256 qam 9
13 227000000 -2 38.6 256 qam 8
14 219000000 -1.7 38.9 256 qam 7
15 211000000 -1.7 38.6 256 qam 6
16 203000000 -1.7 38.6 256 qam 5
17 195000000 -1.5 40.3 256 qam 4
18 187000000 -1.4 38.9 256 qam 3
19 179000000 -1.2 40.3 256 qam 2
20 171000000 -1.2 40.3 256 qam 1
  • 9.36K
  • 801
  • 1.96K
Message 2 of 7
Re: timeouts - power levels on vivid 100
Your power levels and SNR are fine.
The hub communicates with VM's servers every 30s, passing on technical info. so the odd T3 every now and then should not make any difference to the performance to your internet connection. A clutch of T3 errors in a short space of time would indicate a possible impairment.
How is your internet performing on a wired connection to the Hub?
  • 37
kannanni
Message 3 of 7
Thanks for replying. Connection is good wired/wireless all the time. Was looking at the logs as I never had the chance since installation. Finger crossed it will stay like this. Getting over 100 all the time
  • 37
kannanni
Message 4 of 7
sh3 lost sync today and internet went away, please see above logs from modem and let me know if there is anything bad that needs attention:
2017-02-28 17:24:12.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-02-28 17:24:12.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-02-28 17:24:12.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-02-28 17:24:13.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-02-28 17:24:18.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-02-28 17:24:21.0082000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-02-28 17:24:35.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-02-28 17:24:35.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
7123600000ATDMA45.564 qam64000005120
Downstream bonded channels Channel Frequency(Hz) Power
(dBmV) SNR
1299000000-0.738.6256 qam17
2323000000-0.738.6256 qam20
3315000000-1.238.9256 qam19
4307000000-138.9256 qam18
5291000000-1.538.9256 qam16
6283000000-1.738.9256 qam15
7275000000-1.538.6256 qam14
8267000000-1.538.6256 qam13
9259000000-1.938.9256 qam12
10251000000-1.938.9256 qam11
11243000000-238.9256 qam10
12235000000-1.938.9256 qam9
13227000000-1.938.6256 qam8
14219000000-1.738.9256 qam7
15211000000-1.538.9256 qam6
16203000000-1.538.9256 qam5
17195000000-1.440.3256 qam4
18187000000-1.238.9256 qam3
19179000000-1.238.9256 qam2
20171000000-1.240.3256 qam1
yesterday i upgraded to 150/10 and speed stayed rock solid all the time until today at 5 when it all went away and came back by itself. ive rebooted now anyway and keeping an eye on it - speed stays the same at top figures
  • 37
kannanni
Message 5 of 7
Can a MOD please have a look at my connection/sh3 and let me know the findings
  • 37
kannanni
Message 6 of 7
Don't bother replying seems like it's not the best source of support here. I'll seek help through different channels. Good think Im still in time to cancel service
  • 10.71K
  • 314
  • 657
Message 7 of 7
Hey kannanni,
Sorry I didn't get here sooner, we're very busy at the moment and can take a few days to reply.
I've checked your connection and I can see the time-outs are stacking up. I'd like to arrange for an engineer to call around to look into this further.
I'll drop you a PM (purple envelope, top right) to arrange a visit.
Take care.
Heather_J
