  • 7
bruce9903
Message 1 of 5
keep losing both wired and wifi internet connection
Hi ,
Please advise , keep getting the same problem , on super hub 3 , losing both wired and wifi internet connection , also unable to use catch up tv on tivo box. Have tried re-booting everything , router , tivo box , laptop and tablets , but no luck the same problems keeps repeating itself... Becoming more than a bug now !!!!
Cheers
  • 478
  • 62
  • 138
backtothefuture
Fibre optic
Message 2 of 5
Re: keep losing both wired and wifi internet connection
When this occurs does it actually show on the device that you have lost network connection ? - Also does rebooting the router get things back up again (at least initially) ?
If I have helped please feel free to give 'Kudos' by clicking on the thumbs up icon against any of my posts. If I have helped to solve an issue you can also click on the 'Mark As Helpful Answer' link to mark it as helpful.
  • 7
bruce9903
Message 3 of 5
When this happens , the device indicates the we have lost internet connection, also when i re-boot the router it re-connects ok.
thanks
  • 1.28K
  • 96
  • 236
stevedh2
Knows their stuff
Message 4 of 5
When that happens can you connect to the hub at 192.168.0.1 , don't logon but look at its status, what does it show?
also it may be worth setting up a BQM at http://www.thinkbroadband.com/ping as this will also show the pattern of your disconnections
  • 8.38K
  • 362
  • 590
Message 5 of 5
Hi bruce9903,
Welcome to the Community!
Really sorry to hear you're having trouble with your connection.
I've run diagnostics on your equipment and I can see an issue with your Modem SNR that will need to be adjusted by a technician. I've sent you a private message (purple envelope at the top right of your screen) so I can arrange an appointment.
Speak soon Smiley Very Happy
Josh
