  • 8
seapeacox
Message 1 of 9
Wired client on port 1 is running at 100 Mbps
My desktop is plugged directly into new hub 3 router via ethernet Cat 5E cable.  I keep getting following error messages when I do network diagnostic:
"Wired client on port 1 is running at 100 Mbps.
Device connected on port 1 is running at a lower speed of 100 Mbps and is not utilizing the full available speed."
I have 100mbps connection with Virgin and speedtest.net gives average connection speeds of 60mbps to 80mbps.
Are the error messages telling me anything useful or significant?  Should I upgrade ethernet cable from router to desktop?
  • 9.86K
  • 322
  • 850
Hero
Message 2 of 9
Re: Wired client on port 1 is running at 100 Mbps
You could whether or not your desktop can run at 1Gb is another.
Here are good cables
https://www.amazon.co.uk/Duronic-Professional-Headed-Shielded-Network/dp/B003CL8KAQ/ref=sr_1_1?s=com...
https://www.amazon.co.uk/Shielded-Network-Cable-Meters-Ethernet/dp/B0080H66QC/ref=sr_1_3?s=computers...
  • 8
seapeacox
Message 3 of 9
Thanks for quick reply.
I have an Intel(R) 82579V Gigabit Network Connection on my desktop that connects directly to the new hub 3 router via Ethernet CatE cable.
When I do a connection test on the network connection I get following message which seems to suggest there may be a problem with my CatE cable? Could there be any other explanation?:
Cable Length Status : Passed
Cable Length: 4 meters
Cable polarity Status : Passed
Cable polarity normal.
Local Receiver Status : Passed
Remote Receiver Status : Passed
Cable Quality Status : Failed
Cable Quality is poor or no cable is connected.
Possible causes:
Faulty cable, faulty connector, or a speed/duplex mismatch. Verify
that the speed/duplex setting on the switch/hub is configured for auto-negotiation.
Cable Integrity Status : Failed
The test detected a frequency response
that does not meet IEEE specifications.
  • 9.86K
  • 322
  • 850
Hero
Message 4 of 9
sounds about right.
Spoiler
new cable it is then
  • 8
seapeacox
Message 5 of 9
Have now replaced the cable from the router to my desktop with Ethernet Cat6 cable. The network connection test now says cable is fine but I still get this error message when I run network diagnostics test from my new hub 3:
Does this suggest there is problem with cabling in the street or internal cable supplied by Virgin that connects from broadband/telephone/TV junction box to the router?
Regards and thanks again for such a quick reply.
  • 16.08K
  • 1.34K
  • 3.25K
Message 6 of 9
hiya @seapeacox the connection show should read 1gbps/1000mbps even with the coax cable taken out of the hub, it should be showing e.g.
step 2
i would be checking for full duplux -> http://www.home-network-help.com/speed-and-duplex.html since its possible could be a fault with the Network card itself if the all the pins are not making a connection
  • 3.98K
  • 202
  • 893
cybmole
Community elder
Message 7 of 9
buy a cat 6 cable. the white one that Virgin give you is only 5E
& confirm via device manager that your PC has  Gb ethernet onboard - some don't and so 100 is their max
  • 8
seapeacox
Message 8 of 9
Thanks for prompt reply.
It is an Intel(R) 82579V Gigabit Network Connection card and Ethernet status confirms a speed of 1 Gbps.
The card has passed all the link speed tests and I have just replaced the Cat5e with a Cat6 cable. Hope this clarifies setup:
 Connection test:
Connection Status : Passed
Successfully pinged Gateway address
192.168.0.1
Cable Link Status : Passed
This adapter is running at full speed.
Cable test:
Cable Length: 0 meters
Cable Quality Status : Passed
Cable quality is excellent.
Cable Integrity Status : Passed
No cable problems detected.
Hardware test:
Register Status : Passed
EEPROM Status : Passed
FIFO Status : Passed
Interrupt Status : Passed
Loopback Test(s) : Passed
  • 9
FR0STBIT3
Message 9 of 9
i have cat 6 cables and killer e2200 gigabit Ethernet controller and mine says that help?
