garrylish
Message 1 of 11
Why charge £99.99 for shorter cable
Just received my new V6 Box. Yay But not for long.
About a month ago i moved the tv to a different corner of the room.Ready for closing up the wall between dining room and lounge so had to move the splitter cable which has left me with arouns 6-8 metres of rolled up cable behind my tv.
Phoned virgin media and asked if it was possible to have a shorter cable with a filter on the end, The operator said well i roll mine up behind the tv and put an elastic band around it. He further went on and told me that it would cost me £99.99 to send out an engineer to shorten my cable.
To be honest i was disgusted, i have been with virgin media since the start and have been cabled since the old Cable and Wireless, Nynex, and NTL days. I find this a joke as a long standing customer, find myself fuming and turning to social media to announce my horror, surely a customer could order a cable at what ever length they require. than using up their resources of sending out and engineer, wasting petrol, and time where it could be used to install somebody else's new install.
Find myself now thinking of changing companies to one which can supply the right length cable.
Could be a simple remedy why not list different lengths of cable on their website for people to buy if they require one.... Any ideas how i can get a shorter cable would be appreciated, if cant get one within the cooling off period i shall be cancelling, as will be entering into new contract now got new V6 Box.
Helpful Answers
  • 10.7K
  • 1.06K
  • 2.01K
Message 5 of 11
Re: Why charge £99.99 for shorter cable
Changing the cable is not the problem, its the increase in power level that will result from removing 8 metres of cable.
su1718.jpgCable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV6), Talk Anytime Phone, VIVID 350, Virgin PAYG Mobile
All Replies
  • 22.23K
  • 845
  • 3.23K
Message 2 of 11
non fault callouts are £99.
The power levels are balanced in the green box for the distance to the device. changing the cable can alter this so they need to check and reset this if its out of spec.
Why can't you roll out the cable and hid behind the TV?
garrylish
Message 3 of 11
Just seen this on the VM Community about the pricing, somebody with the new V6 box wa going to be charged £49.95 for the new box plus £14.99 activation fee plus £40 installation fee.
Was answered by BanMcr that a self install is available for the V6.There may be circumstances where  it's not available, but if you are offered the choice then you shouldn't be charged the $40 manned install fee.
Only where self install has been offered and you've specifically chosen a manned install would the £40 normally be applicable. This was the reply from somebody from virgin media.
Now it would be £59 cheaper for me to have a manned install than send out an engineer for a non fault, also don't really want 8 metres of cable rolled up behind my tv. Also i was charged £20 for activation so it seems that the price for activation has gone up since that forum post on the 24-03-2017
  • 1.7K
  • 153
  • 458
Message 4 of 11
The official line is they have to do it, but in reality if you use decent quality cable like Webro HD100 it will work fine.
No connection, just the first one I found on Google:
https://www.amazon.co.uk/WHITE-VIRGIN-MEDIA-BROADBAND-EXTENSION/dp/B0074RZ1TC/ref=sr_1_1?s=electroni...
Dave.
  • 10.7K
  • 1.06K
  • 2.01K
Message 5 of 11
  • 1.7K
  • 153
  • 458
Message 6 of 11
About 1.2dB at the higher frequencies? You'd have to pretty close to the limits for it to cause problems.
  • 22.23K
  • 845
  • 3.23K
Message 7 of 11
noise ingress that takes out the node. That can be an expensive mistake as well.
  • 8.62K
  • 438
  • 1.02K
jb66
Message 8 of 11
Maybe expensive for virgin, but not for the customer.
  • 8.8K
  • 600
  • 1.74K
Message 9 of 11
If the customer caused the noise Virgin can bill them for the entire cost of locating and fixing
  • 8.62K
  • 438
  • 1.02K
jb66
Message 10 of 11
No, they cant
