  • 56
Tizzmanizz
Vm hub3 power level
My hub 3 has been giving me issues on the gamer 200 package. Main problem is the unstable connection and I think that's due to the upstream power levels?? I'm using an iPhone so I'm unable to cut and paste my router status but what results do you need to see? My upstream level is 34dbmV and downstream is between -4.7 and -2.5 .
  • 362
  • 16
  • 83
pyrotenax
Fibre optic
Re: Vm hub3 power level
Your downstream is a little too low.
Running ASUS RT-AC88U with Asuswrt-Merlin firmware
  • 12.78K
  • 1.62K
  • 3.78K
The upstream is fine ( goes from 31 to 51) Downstream wise, -6 to +10 is the current VM acceptable downstream power level range, so that side of it is perfectly fine.
______
Any opinions expressed by myself are entirely my own and do not represent Virgin Media in any way.
  • 56
Tizzmanizz
If it's not the upstream power level then what could possibly be the problem? I've literally tried everything and I can't seem to get a stable connection.
