martingerrard
VPN connection with Hub 3
Please can anyone confirm that this works OK?  Looking at switching to VM and have seen a few topics that suggest there are potential issues with it - not sure if these are isolated or if there's a generic issue.  Asked the tech support people and they said it was fine, but somehow didn't inspire me with total confidence that they knew what I was on about.
  • 67
  • 8
mpellatt
Dialled in
Re: VPN connection with Hub 3
Hub 3 in modem mode with PFSense behind it, I have no problems with either inbound OpenVPN terminated at PFSense, outbound OpenVPN both from PFSense and devices behind, or Cisco AnyConnect (IKEv2) outbound from devices behind PFSense.
Can't speak for it in router mode, though. This may not be the answer you need :-)
martingerrard
Mmm, sort of but would be good to know if anyone manages to use it on a normal wifi connection.... if I understand well, modem mode means you're connected on a wire?
