noncencao
Message 1 of 9
Using second wall socket
Hi guys,
I want to use an other wall socket in the house but when I relocated the super hub to that room I had no broadband at all. I called the customer service but they were unable to help and said if I want to use an other socket I should pay for the engineer visit so they can do something about that.
I am pretty sure that they could not understand the situation as I had been transfered to a different person/department 3 times! I fed up in the end as some of them said if I have one socket working in the house then I should use that one even if I definitely need a wired connection in the second room with the second socket.
All I need is a confirmation that even if I have more sockets in the house (totally the same as the one which the super hub had been installed by myself and used in the last 4 months without any issues) I can't use them or if I can, how?
I know about wifi repeaters, etc but I would like to know more about using the second socket directly.
Thank you very much,
Norbert
Helpful Answers
  • 1.28K
  • 96
  • 236
stevedh2
Knows their stuff
Message 7 of 9
Re: Using second wall socket
can you follow the wire for the 2nd socket to see where it goes or is it buried in plaster etc?
All Replies
  • 8.63K
  • 440
  • 1.03K
jb66
Message 2 of 9
If you need a socket activated and you dont know how to do this yourself you would need to pay for an technician visit to do this
noncencao
Message 3 of 9
Is it the same process as I needed to do when I started to use the first socket? Shall I totally reset the super hub then call the automatic activation number and that's all?
  • 1.28K
  • 96
  • 236
stevedh2
Knows their stuff
Message 4 of 9
If the hub is already activated, it shouldn't care which socket you connect it to, unless for some reason the socket is connected to a different feed and not just split from the one coming into your house.
What is the history behind the 2nd socket, there is a chance it isn't live. what path does the wire for this socket take to the properties feed and how does it compare to the 1st socket.
  • 10.73K
  • 1.07K
  • 2.01K
Message 5 of 9
Either the second feed was disconnected when it ceased to be used (which would improve the signal at the existing socket) or the connections/splitters have deteriorated to the extent that they will not pass enough signal for the second point to be used.
There is also the question of whether this is a fault callout or not, as your current setup is working correctly. Non-fault callouts carry a hefty fee.
su1718.jpgCable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV6), Talk Anytime Phone, VIVID 350, Virgin PAYG Mobile
noncencao
Message 6 of 9
Thank you guys for the replies.
Unfortunately I am not aware of the history of the sockets, I hoped the technical service team could help but they said they didn't know anything at all.
Is there any way thatnI can find out these things?
  • 1.28K
  • 96
  • 236
stevedh2
Knows their stuff
Message 7 of 9
noncencao
Message 8 of 9
Thank you guys, for all the helpful replies. I followed the cables outside the house and found the virgin box, opened it and I saw that the cable which leads to the other socket is not plugged in at all. I had only one main cable, so I unplugged the one which was for the original socket, the first one, and simply plugged the other one in. Now it's working fine, I should have started with this, but to be honest I never realised that I have that box on the wall of the house!
Thanks again for you all.
  • 7.59K
  • 188
  • 443
Message 9 of 9
Hi noncencao,
Thanks for keeping us updated. I am glad to see that you have managed to get things resolved with the help of our lovely forum users Smiley Happy
If you do need help in the future the team here as well as our forum members will always be happy to take a look.
All the best
Emma
