  • 12
bloosn
Superhub Power Blokken
Hello there,
I'm running on "borrowed" power at the mo. as my superhub power brik has bricked..
Is there an easy way to get a replacement?
Helpful Answers
  • 16.13K
  • 1.34K
  • 3.27K
Re: Superhub Power Blokken
hiya @bloosn to get a replacement PSU (Power Supply Unit), you can wait about 5+ days for a forum admin to arrange replacement, or could contact support via 150 / 0345 454 1111 online chat http://contact.virginmedia.com (using PC/laptop), if you contact support can you post the outcome here, saves the forum admins a bit of time.
All Replies
  • 16.13K
  • 1.34K
  • 3.27K
