  • 13
mantonl
Message 1 of 5
Super Hub 2AC firmware issue
My Super hub 2AC DHCP server stopped working and this needed a replacement router sending out. As I have many custom firewall ports and reserved MAC addresses set, I did a backup of my Super hub settings through the Backup and Restore option in the super hubs menu. When my new router arrived I went to restore the backup and while I was pointing my router to the backup file it rebooted itself and installed a new firmware V2.01.11. This isn't a problem till I go to do a restore again and find that the new firmware removes the Backup and Restore option in the menu. This then took me an hour to set everything back up and lucky I still had the old router to use as a reference, but now I have no way of saving all the settings. My only point of reference going forward is screen shots of the setting in case I have to hand ball them in again, should it revert back to factory settings or be replaced yet again. Well Done Virgin Media.... NOT!
  • 10.13K
  • 338
  • 896
Legend
Message 2 of 5
Re: Super Hub 2AC firmware issue
  • 13
mantonl
Message 3 of 5
Well just logged on the router this morning and I've been downgraded back to V1.01.11 from V2.01.11 but at least I have my backup and restore options available again. I do hope VM don't reapply the newer firmware again without fixing it so that we keep the Backup and Restore options
  • 22.39K
  • 863
  • 3.26K
Message 4 of 5
the backup and restore options are not likely to be readded. the rollback was due to problems with Xbox Live
  • 7.76K
  • 190
  • 447
Message 5 of 5
Hi mantonl,
Thanks for getting in touch, I don't have any news on whether they will re-add that option if they re-roll out the firmware we had some trouble with. Apologies for that.
Looking at your connection I can see your modem SNR is on the low side, which may cause issues with your connection.
I would like to get an engineer out to take a look at that for you.
I will pop you a PM to get this arranged. Keep an eye out for the Purple Envelope, top right hand corner.
Speak to you soon.
Emma
