Jerry007
Sony TV Remote Control
I have a new sony bravia tv, and the remote control also controls the tivo box , only snag is when i press the tv guide button, it gives me the sony epg, Is there a way to get the tivo epg instead which is much better?
(i've tried the sony forum with no success)
  • 15.84K
  • 1.3K
  • 3.19K
Re: Sony TV Remote Control
hiya @Jerry007 dont think this would be possible without reprogramming the Sony remote, i very rarely use my branded tv remote all done using virginmedia remote.. to the tivo remote to your sony tv you could take a look at -> http://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=3943&CURRENT_C...
Jerry007
Thanks but it looks like i'll have to keep two remotes for now. As it's only the epg problem i have with the sony control, whereas i'd have several issues with the tivo remote , as the sony smart remote has dedicated buttons for netflix and google etc.
dpfuller
Hi Jerry,
did you manage to resolve this, I'm having the same issue?
thanks
