  • 6
thehugills
Slow speed with HUB 3
Can Someone please help.
I have 100mb connection but the internet seems slow, at the moments on the last test using speedtest.net. i am getting 8.45mbps. It was slowish before but now with this hub even slower, i am fed up of being messed around with the call centre. any advice please.
  • 6
thehugills
Re: Slow speed with HUB 3
SFID 52255
Max Traffic Rate 110100000
Primary Upstream Service Flow
SFID 44447
Max Traffic Rate 6400000
  • 10.82K
  • 308
  • 631
Hi there thehugills,
Sorry to read that you are experiencing slow broadband speeds.
I've run some tests on your connection, the line and hub have come back as fine. There are no faults reported and the network segment is running stable with no errors.
Were the speed tests you completed through a wired or wireless connection? If wireless can you try through wired please?
Do you notice these speeds at all times of the day or just at certain times?
Let me know how you get on
Sam
  • 6
thehugills
Still having them same problem, an engineer come out on the 31st and advised it was a utilization problem in my area is this correct, also i have found many other users with the same issue and a fault code F004366467.
Can you confirm when this will be fixed as the tech team are sending another engineer out.
