leighak92
Replacement hub 3
Received a replacement router yesterday as the old one wasn't getting the speed I'm paying for and when I rang up the person on the phone said the hub is faulty. I've changed them over and now it won't connect to the Internet at all. Is there something else I'm ment to do? I've followed all the instructions in the manual.
  • 10.02K
  • 332
  • 877
Hero
Re: Replacement hub 3
If this is over wireless you need to enter the new password thats on the hub 3.
If by wire it should just work if using DHCP or try a new cable.
Or you have a faulty hub 3.
