Greenwood15
Problems with new hub connection
When my 3.0 turned up on the morning of the 24th, I went through the step-by-step in the booklets you get with your quickstart kit and did everything accordingly, but experienced problems activating for half an hour, then when that was solved I experienced problems actually receiving an internet connection in order to complete registration, and then when I finally solved that, the base LED stayed white for about half a minute, then went straight to flashing green, which it has been now since 10pm, it keeps switching between "white base, other leds are green flashing" and just a green flashing base, to a flashing green base with a red internet light. Either way I'm not able to receive an Internet connection, it takes me to that page where it offers to scan for the problem but that gets nowhere every time
Somebody help me please
  • 16.5K
  • 1.38K
  • 3.37K
Re: Problems with new hub connection
hiya @Greenwood15 best to give the activation team a call number should be in the box, since it will be around 5+ days for a forum admin to reply.
