  • 485
  • 7
Taf
Up to speed
Message 1 of 465
On-off-on-off connection after power up
I power the SHUB down each night for several reasons. Some mornings it boots up perfectly, other days it's on-off-on-off for around an hour sometimes. After 2 days with no problems this is the typical situation:
23/09/201515:14:36 GMT66050310Auth Success - Web login successful.
23/09/201506:56:23 GMT68010302DHCP WAN IP - 81.105.50.232
23/09/201506:55:46 GMT68000407TOD established
23/09/201506:55:35 GMT84000510Downstream Locked Successfully
23/09/201506:54:52 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
23/09/201506:53:52 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
23/09/201506:52:52 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
23/09/201506:51:52 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
23/09/201506:50:52 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
23/09/201506:49:52 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
23/09/201506:48:52 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
23/09/201506:48:08 GMT67070100DBC-ACK not received
23/09/201506:48:06 GMT85010200TCS Partial Service
23/09/201506:47:59 GMT68010302DHCP WAN IP - 81.105.50.232
23/09/201506:47:22 GMT68000407TOD established
23/09/201506:47:11 GMT84000510Downstream Locked Successfully
23/09/201506:46:29 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
23/09/201506:45:29 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
23/09/201506:44:29 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
23/09/201506:43:29 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Downstream ChannelsLock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked9299000000 Hz256 QAM1.2 dBmV 37.9 dB1297271
Locked5267000000 Hz256 QAM1.2 dBmV 37.6 dB5510294
Locked6275000000 Hz256 QAM1.3 dBmV 37.9 dB855297
Locked7283000000 Hz256 QAM1.0 dBmV 37.4 dB529282
Locked8291000000 Hz256 QAM1.0 dBmV 37.9 dB923923
Locked10307000000 Hz256 QAM1.3 dBmV 37.9 dB294285
Locked11315000000 Hz256 QAM1.3 dBmV 38.3 dB929929
Locked12323000000 Hz256 QAM1.5 dBmV 38.3 dB289288
To reset the Pre and Post RS error counts please use the Downstream screen under the router status screen available from the login page.
Upstream ChannelsLock Status Channel ID Frequency Modulation Tx Power Mode Channel Bandwidth Symbol Rate
Locked3439400000 HzATDMA42.8 dBmV64QAM6400000 Hz5120 Ksym/sec
NotLocked00 Hz 0 dBmV  0 Ksym/sec
Locked3532600000 HzATDMA42.3 dBmV32QAM6400000 Hz5120 Ksym/sec
  • 485
  • 7
Taf
Up to speed
Message 2 of 465
Re: On-off-on-off connection after power up
A tech came out last week and found everything to be OK.
  • 10.15K
  • 339
  • 896
Legend
Message 3 of 465
It is strange that it becomes stable after being on long enough.
If you turn it off now then back on does it go on-off-on-off before being stable?
Hard to tell whats at fault maybe a firmware boot up problem, some type of fault with the super hub or PSU or an issue with the Docsis network on a cold super hub boot up to get going.
  • 14.48K
  • 641
  • 1.46K
Moderator
Moderator
Message 4 of 465
Hi Taf,
Those T4s don't look great on the network log. I've checked your connection from here and I can't see anything wrong. The next time you get this on off issue when booting up could you check the network log again and see if the same T4s show up?
  • 485
  • 7
Taf
Up to speed
Message 5 of 465
More T4's today whatever they are....
25/09/201517:27:31 GMT66050310Auth Success - Web login successful.
25/09/201508:51:43 GMT68010302DHCP WAN IP - 81.105.50.232
25/09/201508:50:44 GMT68000407TOD established
Time Not EstablishedTime Not Established84000510Downstream Locked Successfully
24/09/201510:00:22 GMT68010302DHCP WAN IP - 81.105.50.232
24/09/201509:59:45 GMT68000407TOD established
24/09/201509:59:33 GMT84000510Downstream Locked Successfully
24/09/201509:59:14 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
24/09/201509:58:51 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
24/09/201509:57:51 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
24/09/201509:56:51 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
24/09/201509:55:51 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
24/09/201509:54:51 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
24/09/201509:53:51 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
24/09/201509:52:51 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
24/09/201509:51:51 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
24/09/201509:51:08 GMT67070100DBC-ACK not received
24/09/201509:51:06 GMT85010200TCS Partial Service
24/09/201509:51:00 GMT68010302DHCP WAN IP - 81.105.50.232
24/09/201509:50:21 GMT68000407TOD established
  • 14.48K
  • 641
  • 1.46K
Moderator
Moderator
Message 6 of 465
Hi Taf,
Thanks for posting the log again. I still can't see anything to cause the T4s so let's get a technician to check the local network and your connection to see what is causing this.
I've just sent you a private message to arrange the best time for this.
  • 485
  • 7
Taf
Up to speed
Message 7 of 465
I had a tech out just recently, and he could find no problems. It appears to have cleared over the past couple of days. I'll monitor and post any problems that reappear, as I will not be available to be home for another tech visit for a short while.
  • 485
  • 7
Taf
Up to speed
Message 8 of 465
And it's back :-(
01/10/201509:08:50 GMT66050310Auth Success - Web login successful.
01/10/201509:08:40 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
01/10/201509:07:58 GMT67070100DBC-ACK not received
01/10/201509:07:56 GMT85010200TCS Partial Service
01/10/201509:07:48 GMT68010302DHCP WAN IP - 81.105.50.232
01/10/201509:07:10 GMT68000407TOD established
01/10/201509:06:59 GMT84000510Downstream Locked Successfully
01/10/201509:06:19 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
01/10/201509:05:19 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
01/10/201509:04:19 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
01/10/201509:03:19 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
01/10/201509:02:19 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
01/10/201509:01:19 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
01/10/201509:00:19 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
01/10/201508:59:36 GMT67070100DBC-ACK not received
01/10/201508:59:34 GMT85010200TCS Partial Service
01/10/201508:59:26 GMT68010302DHCP WAN IP - 81.105.50.232
01/10/201508:58:49 GMT68000407TOD established
01/10/201508:58:39 GMT84000510Downstream Locked Successfully
01/10/201508:58:00 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
  • 485
  • 7
Taf
Up to speed
Message 9 of 465
  • 485
  • 7
Taf
Up to speed
Message 10 of 465
Locked9299000000 Hz256 QAM1.1 dBmV 37.9 dB354287
Locked5267000000 Hz256 QAM0.9 dBmV 37.6 dB653278
Locked6275000000 Hz256 QAM0.9 dBmV 37.4 dB337281
Locked7283000000 Hz256 QAM0.7 dBmV 37.4 dB315289
Locked8291000000 Hz256 QAM0.8 dBmV 37.1 dB279278
Locked10307000000 Hz256 QAM1.0 dBmV 37.9 dB300298
Locked11315000000 Hz256 QAM1.1 dBmV 37.6 dB972971
Locked12323000000 Hz256 QAM1.2 dBmV 37.6 dB283282
Locked3439400000 HzATDMA43.0 dBmV32QAM6400000 Hz5120 Ksym/sec
Locked3532600000 HzATDMA42.5 dBmV16QAM6400000 Hz5120 Ksym/sec
