Matt89
Just joined
Need help!!!!
Green arrows will not stop flashing on my hub 3.0 but the wifi symbol is staying solid green and the base light is white and not green like it should be.
Any ideas what the problem could be????
  • 20.53K
  • 542
  • 3.16K
Sephiroth
Re: Need help!!!!
Is it service affecting?
  • 7.2K
  • 173
  • 420
Re: Need help!!!!
Hi Matt89,
Welcome to the forums, I am sorry to see you have been having trouble with the lights flashing on your hub.
If it not service affecting then I would not worry about the lights flashing particularly.
I have tried to take a look at your connection to be sure there are no other issues but I have been unable to locate your connection details.
I will pop you a PM to get some more information and we will take it from there. Keep an eye out for the Purple Envelope, top right hand corner.
Speak to you soon.
Emma
