sshort13
My Superhub power supply has broken!!
The lead has broken on my Superhub power supply. How do I get a new one?
  • 16.08K
  • 1.34K
  • 3.25K
Re: My Superhub power supply has broken!!
hiya @sshort13 welcome to the virginmedia community forum, you can wait a few days for the forum to pick this up and arrange replacement, or you could contact broadband support via 151 / 0345 454 1111 online chat @ http://contact.virginmedia.com (using PC/laptop), if you do contact support can you post the outcome here saves the forum admin a bit of time.
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Hi sshort13,
Thanks for the post! Sorry to hear that your Super Hub's power supply has broken. I apologise for any troubles incurred, I will do my best to help get this sorted for you.
I have had a look at your connection from here and everything is online and looks great! Have you solved this issues already?
Please respond to me here and I'll get this sorted for you if need be.
Take care,
Adam.
