  • 699
  • 18
mitch84
Superfast
Max Length of cable without deterioration.
I run a fairly long length of network cable down the side of the house in underground trunking, not sure if its 5/5e/6 as it was installed a long while ago.
I get excellent performance, but Im going to need to add a bit more cable length to the inside of the house as Im going to be eventually moving my n66u router more centrally and the SH1 will be in modem mode which is at the front of the house and cant really be moved without a lot of hassle.
What is the maximum length without deterioration?
At a guess I would say if I add all the cables together from the n66u to the iMac I have wired it will be about 40metres.
Cheers
  • 8.8K
  • 600
  • 1.74K
Re: Max Length of cable without deterioration.
Max run length is about 100 meters
  • 699
  • 18
mitch84
Superfast
Ah thats plenty more than I would use.
intgom
Hi dannylau
100m... Is that from the street or the cabinet?
  • 195
  • 19
  • 46
tekmobile
Superfast
intgom wrote:
Hi dannylau
I believe the question was for the users local cat5e/cat6 network cable not the coax from the cabinet
I do not work for virgin media any opinions I have are my own
I will help out when possible but know that some information may be incorrect or out of date
If you find any post helpful don't forget to click the kudos button and mark answers as helpful as this may help other users with the same questions
  • 22
robaldred
There are a few factors that would affect the degradation mainly interference.
If possible ensure it's a single run & use good quality well shielded cat6.
