  • 24
Finners88
Keep losing connection
Been going on for a few weeks now that after a few days I will lose the internet and require a reboot of the super hub. Got really bad tonight before dying just after 8 oclock and I rebooted and you can see below it cleared up. What could be causing this?
84444b852ddc30cb254e3d0426c5407c-22-03-2017
This is my Downstream power levels, sorry about the formatting
Frequency (Hz) 218750000 Hz 226750000 Hz 234750000 Hz 242750000 Hz 250750000 Hz 258750000 Hz 266750000 Hz 274750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 7 8 9 10 11 12 13 14
Modulation QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Depth I=12 J=17 I=12 J=17 I=12 J=17 I=12 J=17 I=12 J=17 I=12 J=17 I=12 J=17 I=12
Power Level (dBmV) 2.7 dBmV 2.5 dBmV 2.3 dBmV 2.2 dBmV 3.2 dBmV 3.0 dBmV 2.7 dBmV 2.2
dBmV RxMER (dB) 43.2 dB 43.2 dB 43.2 dB 43.2 dB 43.6 dB 43.3 dB 43.2 dB 43.2 dB
  • 8.32K
  • 357
  • 586
Re: Keep losing connection
Hi Finners88,
Thanks for posting!
Sorry to hear you're having trouble with your connection.
I've checked your account and there are no network issues currently affecting your area. I've also run diagnostics on your equipment and I can see quite a few timeouts on the log since the last reboot.
I'd like to arrange for a technician to check this out for you. I've sent you a private message (purple envelope at the top right of your screen) so I can arrange an appointment.
Speak soon Smiley Very Happy
Josh
