juliehobbs128
Message 1 of 7
Hub 3 problems
I connected my new Hub 3 last night, following all the instructions, to find that it wasn't working, I called 150 and whilst on hold it started working as I was able to access the internet. However, this lasted for about 30 minutes then the wi-fi light started flashing green as did the base LED light. I unplugged both hub re started my mac which seemed to cure it. However when I shut down my mac within 10 mins the internet had disappeared again and the same thing happened. I did the same thing this morning turning off the hub, only for the connection to drop once i had shut down the mac. I have had a superhub for a number of years and never encountered any problems whatsoever, so am rather perplexed as to why this is happening? Has anyone encountered anything similar?
  • 538
  • 45
  • 129
Corinneangela
Rising star
Message 2 of 7
Re: Hub 3 problems
Did you leave it turned on long enough for all the updates to come through? Can take about 30 mins or more to fully update
juliehobbs128
Message 3 of 7
Re: Hub 3 problems
Yes a couple of hours.
I am thinking of returning to my Superhub 2
  • 538
  • 45
  • 129
Corinneangela
Rising star
Message 4 of 7
Re: Hub 3 problems
If you do go back you need to activate the Hub2 again..
juliehobbs128
Message 5 of 7
Re: Hub 3 problems
Yes I've just seen that. I should have looked at the forums before I upgraded as I have never had any problems with my broadband before!
  • 538
  • 45
  • 129
Corinneangela
Rising star
Message 6 of 7
Re: Hub 3 problems
I would call Virgin first to see if they can fix it before reverting..
juliehobbs128
Message 7 of 7
Re: Hub 3 problems
I will give them another call.
Hopefully, after being on all day it might have started working!
