  • 5
BrianCanavan
Hub 3 connection problem
Just set up the Hub 3 and both lights are green ...bottom light is white need a bit of help please
  • 16.5K
  • 1.38K
  • 3.37K
Re: Hub 3 connection problem
hiya @BrianCanavan the white light is fine at the bottom, here is a guide for understanding the lights -> http://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=27651&CURRENT_... also did you call and active the hub?
  • 5
BrianCanavan
Yes already read that article @paultechy both the wifi and data lights are solid green
  • 16.5K
  • 1.38K
  • 3.37K
if the data light is solid green as the article "The internet light will flash when it is acquiring a connection and, once connected, it will remain on for 2 minutes before going off. It will also flash if the Hub 3.0 is downloading new software. Otherwise, the light will only remain lit or flash if there is an issue with the connection." i would be giving broadband support a contact via 150 / 0345 454 1111 online chat @ http://contact.virginmedia.com (using PC/laptop), since a fault somewhere
